Mines on ADS and down button. It shows LT, what is that? I dont have a controller connected, just KB&MTime to roll out a tac stance build - so you can actually see what yer shooting at![]()
Default is melee while ADS to activate the tac stance - a canted look - I find it really useful with the all visual shake in current game compared to WZ1. Should be decent builds for the tac evolvere and BP50 - I use one of them with a sniper usually. You might not like it but give em a try I would sayMines on ADS and down button. It shows LT, what is that? I dont have a controller connected, just KB&M
Sound still totally broken?
I love the fortunes keep remake map, but the sound makes it sometimes unplayable.
e.g. just now on a solos I was in the final circle and near the buy station in graveyard. I heard footsteps, I preaimed and shot at someone who I thought was hiding just around a corner in graveyard. It turned out they were not there at all and behind a wall but it sounded like they were next to me. Other times you hear nothing then someone is right on top of you.
Killcam yesterday to the enemy (on the killcam anyway) my footsteps were loud. To me, I couldnt hear anyone at all.
How did they manage to mess up the sound so much when it worked perfectly in Moden Warfare 2019. Verdansk in 2020/2021 was still the peak of Warzone IMO.
So many good times on that map, great selection of weapons before they got all stupid with odd names for the MP5 and MP7 and before the Cold war weapons merged into the game.
Bunkers were insane but so fun.
I'm pretty sure Activision would have made more money sticking with that map and just adapting it slightly and adding things to buy (with changing the mechanics of the game too much) The map also looked way better than anything else
Here's a couple reminders of the good times. Pretty sure it looked better 4 years ago too!
The odd thing is, on Warzone on the killcam I can hear my footsteps and it sounds like an elephant running up the stairs. But when I get killed I hear no enemy footsteps when they're runing towards me.Havent played warzone in ages, but on multiplayer, there arent any footsteps anymore. Everyone uses covert sneakers, no reason not to, so everyone runs around in silence. isnt this the same on warzone? or are there no covert sneakers in warzone?
Multiplayer has no atmosphere now.
bit fed up with it, so playing some single player games for a bit. currently enjoying metro exodus... except for the bugs, but they havent been too problematic so far
What the hell are covert sneakers??![]()
@ 2024-02-23 12:46
At the moment it appears that there is a problem when you logon and try to play.
Everything has been reset back to 0 - your loadouts, rank, events, no battle-pass etc.
I haven't logged in to play - glad I didn't.
https://www.reddit.com/r/ModernWarfareI ... _deranked/
https://downdetector.co.uk/status/call-of-duty/
https://www.charlieintel.com/call-of-du ... es-306690/
They added some pointless path tracing to menu so I would check that is what is hammering FPS for no good reasonMines done this.
Menu is also grinding my GPU to 22fps. 3090Ti. This is with fps limited in NCP to 97fps
Turned that off and now its much better - back to normal in menu. ThanksThey added some pointless path tracing to menu so I would check that is what is hammering FPS for no good reason![]()
Yes very annoying, can’t make any classes etc as everything is locked away.Everyone rank reset to 1 what a cluster of a game this is from technical side nothing but problems.
If you're on PC its well worth doing the sound tweaks that Art Is War puts out. His latest one from a day or 2 ago is an absolute game changer. https://www.youtube.com/watch?v=dTzW5OXKaisHavent played warzone in ages, but on multiplayer, there arent any footsteps anymore. Everyone uses covert sneakers, no reason not to, so everyone runs around in silence. isnt this the same on warzone? or are there no covert sneakers in warzone?
that should be the other way around... controller players dont need to aim anywayFlash and stun grenades still useless against controller players (even without battle hardened) I threw a flash gren at someone and his streen went slightly blurry, he/she didnt have battle hardened, no perks at all.
When I get flashed, I get a full screen of white and cant see anything for at least a second.
I'll check that out. ThanksIf you're on PC its well worth doing the sound tweaks that Art Is War puts out. His latest one from a day or 2 ago is an absolute game changer. https://www.youtube.com/watch?v=dTzW5OXKais
