Hi all,
I'm looking to get a 1440p monitor to go with my new incoming 4080S and this looks like a good bet.
I was tempted to push the boat out and go for an OLED but I'm mega-fussy and issues with dimming when the screen is mostly white will do my head in. I've also debated UW but think it'll be a headache compared to having a separate 2nd screen with stuff open while gaming.
Am I likely to have frustrations with light bleed/dead pixels or are these generally spot on? Also am I going to be stuffed using HDR if a 2nd screen doesn't support it?
I see you can make use of a premium panel exchange scheme but it only mentions stuck bright pixels, not dark ones. I suppose I can just return one with dead pixels less than the threshold under DSR?
Any opinions or suggestions gratefully received
EDIT: Also, am I a moron for thinking that a 4K screen would be a bad idea? I want to enjoy high frame rates hence the 1440p angle.
