Asus STRIX B650E-F with Ryzen 5 7600 - Wise to disable onboard iGPU?
15 Nov 2003
Marlow
So I believe you can disable the onboard iGPU in the Bios... Should I? Seems some sites say it improves the performance on the main GPU?
Used mine to install Windows before I put the 4090 in, since then it's been disabled on 7950X3D, can't say I've noticed a performance increase / decrease.
No reason you shouldnt if you are OK with losing that fuctionality, I like having the option to use it as an extra Display Output in case I need to trobleshoot a GPU for whatever reason, or just an extra output if I need it.
Not sure if there will be significant performance gains or not tbh.
And you just took the option in the BIOS to disable the onboard graphics?
If I ever want it back I can re-enable it or worse case reset the bios/cmos...
