Cheap garden wall options?
28 Sep 2003
London
What is a cheap way to replace this garden wal that is falling.
Currently made from decking
Was thinking railway sleepers or any other suggestions.
thank you in adance.
13 May 2022
North East
Cheapest. 2x2 treated timber stakes. Knock them in then screw the original boards to them. Softwood sleepers are £20 for 2.4m, Oak around £40. Scaffold boards can be had for £12 up here
18 Oct 2002
First job soon as spring hits.. lawn is quite waterlogged, not sure how to deal with that.
That would depend on if it's a temporary problem, aerate the lawn and put sharp sand or grit in the holes. If it's a more permanent problem you will have to get better drainage in
