Mini-ITX Upgrade
JRJ
JRJ
21 Oct 2010
Looking at upgrading my current mini-ITX build which is housed in a Silverstone SG13 which I want to keep, although it's sufficient for day to day office tasks it's really showing its age with photo and video editing, it also doesn't meet the requirement for Windows 11 upgrade, current spec is below, where can I go with it, haven't touched it in about 6 or 7 years.
Operating System
Windows 10 Pro 64-bit
CPU
Intel Core i5 4690K @ 3.50GHz
Haswell 22nm Technology
RAM
8.00GB Dual-Channel DDR3 @ 799MHz (11-11-11-28)
Motherboard
MSI Z87I GAMING AC (MS-7887) (SOCKET 0)
Graphics
SyncMaster (1680x1050@60Hz)
2048MB ATI AMD Radeon HD 6670 (MSI)
Storage
111GB Samsung SSD 850 EVO 120GB (SATA (SSD))
111GB OCZ-AGILITY3 (SATA (SSD))
Pretty much anything you buy now is going to blow your current setup away. I'd definitely allow budget for a decent monitor if you're into video/photo editing
What PSU are you using - are you reusing it? What's your budget?
@Tetras @covenantuk thanks for the replies both, initial bottleneck is the Windows 11 upgrade, I've not run Photoshop or Lightroom in about 4 years while life got busy but during bulk editing then it started showing its age so I'm anticipating the latest versions being worse.
Budget wise I don't really want to go over £1k, I don't need top of the range just something pretty decent that'll last a few years.
New monitor is on the shopping list and is a seperate budget to this :D
PSU is a Silverstone 300w or 350w off the top of my head, likelihood is this will need to be factored in as well.
Main problem with sticking to ITX is the cost of the motherboards and PSU.
On your budget, to get a decent GPU you're looking at a DDR4/LGA1700 motherboard Intel build, but this means current gen CPU is the most you'll be able to fit.
If you're going to do any gaming, I'd consider getting an 6700XT AMD card with more VRAM but its a tradeoff with Nvidia DLSS
[*] 1 x Thermaltake Toughpower SFX 850W 80 Plus Gold Native PCIE 5 Power Supply (SKU: CA-1BU-TT) = £189.95
[*] 1 x Thermaltake Kettle Plug Mains Cable (SKU: CB-001-OG) = £0.00
[*] 1 x Gigabyte B760I AORUS PRO DDR4 (LGA 1700) DDR4 ITX Motherboard (SKU: MB-5BY-GI) = £209.99
[*] 1 x Team Group 8Pack RIPPED Edition 16GB (2x8GB) DDR4 PC4-28800C14 3600MHz Dual Channel Kit - Black/ (SKU: MY-001-8P) = £79.99
[*] 1 x Nvidia Fight For Freedom Bundle - Overwatch 2 Invasion (SKU: DIG-NVI-00681) = £0.00
[*] 1 x Asus GeForce RTX 4060 Dual 8GB GDDR6 PCI-Express Graphics Card (SKU: GX-49H-AS) = £299.99
[*] 1 x Intel Core i5-12600K 3.70GHz (Alder Lake) Socket LGA1700 Processor - Retail (SKU: CP-69X-IN) = £239.98
[/LIST]
Total: £1,027.90 (includes delivery: £7.99)​
The reason I asked is because these apps have been updated over time and they now use the GPU with some tasks and so, it's difficult to make a specific recommendation without knowing if you're mainly bottlenecked by the CPU, GPU or something else.
My basket at OcUK:
Total: £1,007.88 (includes delivery: £11.98)​
I checked compatibility with your existing case as best I could and I think everything is alright, but best to double check. If not, I have suggested a different case, which you can remove to fit a better cooler (than the CPU's box cooler) within the budget.
Upgrading the CPU to an i5-13500 is highly recommended (similar price, has 4 more E-Cores, a more powerful IGP and 2 codec engines), but OCUK don't sell it.
I'm not sure if the 4060 offers anything beneficial for Photoshop/Lightroom, so I went with VRAM (Puget's benchmarks for the 3060 Ti and 4060 Ti seem to suggest the answer is no and the 4060 Ti is actually slower in Davinci :o ).
Thanks both, I'll take a look through those over the weekend, @Tetras I'll take onboard the 13500 comment also.
I think I'll download the latest Adobe software this weekend and see if I can test my current setup a bit better, I know scratch drives are no longer needed for Lightroom Libraries so other stuff has more than likely changed.
Revisiting this again as I never got around to upgrading, 7 months went quick :eek:
I've been playing around with setups on ************ and only seeing a few £100 difference between high end and mid spec systems but not sure if it's complete overkill or just future proofing, I'm likely to be using this for the next 6-8years so don't mind spending now if required.
I'd still like to keep the SG13 as I can't really find anything similar but I know it'll be tight.
So top end I've come up with
Intel Core i7-14700K 3.4 GHz 20-Core Processor
Asus ROG STRIX Z790-I GAMING WIFI Mini ITX LGA1700 Motherboard
Crucial Pro 64 GB (2 x 32 GB) DDR5-5600 CL46 Memory
Western Digital Black SN850X 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive
Gigabyte EAGLE GeForce RTX 4060 Ti 8 GB Video Card
I'm hoping the Noctua NH-L12S will be enough, this is my starting point/upper end? Anyone have any observations?
You could drop to the b760 versions of that motherboard and save yourself a £100+ but you get less ports so do a comparison.,
64gb memory makes sense and take a look at Zotac models of the GPU as they offer a 5 year warranty if registered within 30 days otherwise it's 3 years.
There are contradictions on max GPU length on the out case on the sugo site it says 270mn/10.6" but the gigabyte eagle 4060ti is 272mm so be aware.
The Zotac I reccomended is only 225mm in length.
The NH-L12S will make the 14700k throttle if fully loaded but an undevolt or power limit restriction mite help.
Thanks @mickyflinn the b760 is the other MB sat in my basket, with the Noctua cooler and case there's no hope of overclocking currently, but with a case and cooler swap later down the line it's doable, head versus heart battle.
Thanks for the GPU suggestion would be a much easier fit, the 272mm is possible with a very slight mod but shorter would be easier.
I do have the ability to mount a 120mm AIO in the front of the case but reviews for that size say they don't offer any benefit over air cooled.
You don't want to be overclocking you should ideally be looking to undervolt as the intel chips are at there Thermal limit.
What size/form factor PSU do you have ?
Currently a 300w SFX PSU which will need upgrading as well and will stay SFX size.
Do you even need the graphics card? Intel's IGP is pretty capable.
For multithreaded load with a modern i7? Not likely, but you could power limit it as mickyflinn suggests.
See here:
See here:
Thanks @Tetras I'll take a read.
Graphics card, heavy lightroom/photoshop and some video editing, assumed I would need something decent?
I think I need to stop being stubborn and explore new itx case options.
It depends. For 2D, if you're using features that are GPU heavy (e.g. photoshop has an AI denoise), or an app that funnels a lot of work to the GPU, then yes, but the IGP is more than powerful enough to handle a 3D viewport and QuickSync is stupidly powerful for the small cost in getting the IGP over a F/KF.
If you have managed to survive with the HD 6670, then it suggests you weren't using many/any GPU accelerated features.
For video editing: you might want to watch this:
So I've been bouncing between NR200 max and A4 H20 reviews overnight and I think I'm going to go with the A4 H2O, overall capacity is the same as the SG13 but gives me room for a 240mm AIO.
I wouldn't really say surviving, I've barely used Adobe products over the last 4 years whilst building a house and didn't really notice it much using the Capture one express from Sony, but using the trial version of LR and PS with the new AI features really showed its age with simple AI removal taking about 10mins for some images.
So just to update this, I went on a spending spree last night and ordered the following -
Coolermaster NR200P Max which includes a Coolermaster 850w SFX PSU and 280mm AIO
Intel i7 14700k
Asus Rog B760-i motherboard
64GB Corsair Vengeance DDR5-5600
WD Black SN850X 2TB M2 SSD
Just working out which 140mm fans to replace the stock fans with plus I'll add 2 120mm to the bottom of the case.
Left to buy - a new GFX card this ones been the tougher choice to decide on so will run internal GFX until I can decide, also need a new monitor.
Case is a little bigger than I originally planned (A4 H2O) but factoring in the limitations of AIO on that case the added space and extra fans should keep the toaster a little cooler.
Take a look at this review it has some interesting point about that case which mite help you.
