- 23 Jun 2015
in your video when you set custom fan curve did you also select fan2 at the top or just fan1?
afaik looking at it fan 1 includes both radiator fans and fan 2 is the gpu one thats doing nothing so try setting that manually.
when you start up the pc do all 3 fans spin up when you turn it on? if not its dead fan
cant believe i logged in just for this![]()
Hi,
I appreciate your help.
Here you can see I've set fan 2 to maximum and GPU shows no RPM.
fan 1 is also set to maximum and GPU does acknowledge the speed and the RPM.
