You'd got another 20 years (minimum) of paying for her yet. Just think of everything you could have in that time!
Point 1 slightly superfluous to use Total time as a calculation... Not only is it hard to judge the effort the same. But factoring in traffic, junctions etc can be really hard too!Few interesting points
- I was only around 10% faster on my road bike. Considering the MTB has 2.5" knobbly tyres and high gearing to avoid being able to get much speed in. It was a little windier today, but not enough that i'd expect it would make a difference. MTB is around 14kg vs 7.5kg of my road bike
- The Max speed is actually very close. This will be on a downhill, but i'd have thought the lower gearing and being able to actually "pedal" on the descents, along with a more aero position would make a bigger difference
- My road bike has a power meter which recorded an average power of 201W. The Strava estimated average power on the MTB is 121W. This likely shows that i'm fat and Strava doesn't realise how much effort i have to put in to still go slow
- Strava relative effort was 41 today vs 54 yesterday suggesting today was easier. I did try my best to not "race" to provide a reasonable comparison, but both felt similar
Ahaha yeah, lets just say that she isn't 'short of a few bob' having a home in the UK & south Portugal. Has 2 Stages smart bikes as well - 1 in each home!what a horrible life some have ehh......
I feel like I heard somewhere else that doping was still big in the amateur scene. I guess on the whole there is a lot less testing?
I can understand a professional feeling like they need to dope but an amateur at some no name race? That's just wild.
I've been with Admiral , try them . just swicthed to M&S LOLWho are people using for home insurance?
I was with marks and spencer underwritten by Aviva but the cost to renew is up 25%!
You just declared max bike value with M&S which I put at £5000 but again, difficult to put a value on a bike which isn’t off the shelf…
I only have summer & winter which are of any value. Perhaps £2k and 5k respectively but cost to replace like for like would be 12k+ now as prices are stupid…
My advice fwiwJust on the back of my post about signing up for my first Gran Fondo. Had a few questions for those of you most experienced.
When training for a marathon in running there are a few base guidelines around volume etc. is there similar for cycling?
Is it needed to aim for a minimum volume per week either in hours or distance? On average of course catering to recovery weeks.
As I’ve never ridden with anyone other than my wife. Is it worth getting out for group rides to practice riding in a bunch?
Any specific free plans to try and follow? I’ve mentioned before but Garmin massively over estimates my FTP which makes their training plans a bit rubbish.
Even 30mins daily will help a lot with endurance.Just on the back of my post about signing up for my first Gran Fondo. Had a few questions for those of you most experienced.
My advice fwiw
If you have a power meter or a smart trainer then the Garmin Gran Fondo plan would be a good structured plan. I also find their ftp estimates to be reasonable. You can also manually adjust in the Connect app.
To begin with building time on the bike is probably as important as anything. Not sure how long your Gran Fondo is but if its 100m/160km its a long time on a bike. At least 6.5 hours for a beginner. Bodies take time to adjust to that and I would progress steadily from an hour in half hour increments.
Fueling over long distance is also really important. I'm useless at it. Better to eat little and often but over that distance you are looking at 3000 kcal. Hot climates also need careful fluid management. Aren't you based in Spain - in which case you willl be necking a bottle an hour or so. I'd be having electrolyte in one bottle and energy mix in another.
Group rides are useful for learning ride etiquette but unless you are racing my expereince with sportives is that you are seldom grouped that tightly except for the start.
So in summary - time on the bike - but build steadily. Fuel and water strategy and maybe the odd group ride as you build the distance. Rid'ng long distances solo can be boring.
I used to sweat a lot on the bike and had to hydrate a lot.. much better now and that is with help of daily commute with no water - 45mins one way for me .
From what I recall your Fondo has quite a lot of elevation , so more training the better...food and water.
If you can find a group to train with or just cycle with that will help. Learn a bit how to stay on the wheel and draft .
And deffo don't kill yourself doing it...do not push all the time
160km sounds a lot but it ain't![]()
Yeah, I would mix simple time in the saddle, with an actual training plan.
For me, long rides at the weekend and workouts on weekdays after work, works quite well.
Jerseys - it varies but the one I got for doing the Maratona a few years ago was great - Castelli made and also got a cracking gilet which I still wear! Retail prices for cycling clothes are crazy. Decathlon is fine for jerseys. Shorts worth spending a bit more and fit is all. I personally like Santini.Cheers guys. I'm not overly worried about the distance. I've done much longer duration based events with running, so fueling/hydration i'm fairly comfortable with. From a guess i'd say i'm targetting 8-9 hours given the elevation.
I'd say looking at my history, i've averages around 2x 1hr rides a week for the most part. In December i had a decent couple of 2-3hr rides ad then trailed off in January as work for bad and February as the roads at my parents were too busy and i didn't enjoy it as much. As you say time in the saddle is probably a big factor. I definitely get uncomfortable on anything >2hrs and find myself shifting around a lot. I considered finding a bike fitter, but since i've got a fixed stem/handlebar (for the looks!) there's only really stem height and saddle i can play with without starting to spend big and i think i can explore those myself, my thinking on yesterdays ride was that both are a bit low.
The Strava estimated FTP sounds much more likely. Garmin thinks it's 280w which i think is a bit high. I know i can change it manually but then it kind of ruins the ability to see progression and it's nice it auto calculates! I'll admit i've never done a formal FTP test, but with the Garmin training it thinks holding 240w is relatively easy!
@bastic Yeah, 3700m of elevation over 166km. Yesterday i did 44km with 485m elevation so more or less 1/4 of the distance but with an 8th of the elevation. It's definitely the hills i need to be stronger on. As mentioned, i'm hoping it gives the incentive to drop the weight! Plus i've got to October so a good amount of time to get better.
The other concern i have is speed. I'm not a particularly fast cyclist (was never a fast runner either!) and yesterdays ride was around a 24km/h average pace. I'm sure when entering the event i had to put an estimated pace and the lowest category was 25-28km/h so i'm not even fast enough for the bottom threshold and that's without factoring in the distance/elevation! Obviously speed should improve with training (another reason i think a plan might help me) but it does worry me a little!
"During the march, those who cannot follow the set pace and are overtaken by the green flag will be out of the race, so they must slow down and drive with caution without hindering the rest of the road users who pass through them and complying. traffic rules and traffic signs."
That deffo might apply to me!
Hmmm, the other concern is Jersey size. Apparently it has to be worn during the event. I'm generally between sizes a lot between L-XXL depending on brand, and especially with the hope of losing weight that could change again. The brand is Gobik, i'm wondering if i should try and order one ahead of time to check sizing. Last thing i need is something not fitting during a long ride!! The other assumption is that the quality of a "free" Jersey will be considerably less than that of a bought one, given their website shows prices around €80-€100 and the event is only €45! So could be wildly different anyway. Or am i overthinking things here?
Speed - always elevation dependent. I a lumpy ride you will struggle to maintain 15mph average. I had an ftp of 280w at 76kg at my fittest a few years ago and the Maratona and etape were like 12mph averages! Endurance is more important. Speed comes the more you ride and the lower your weight. Some events do have a broom wagon but you have 6 months to get in shape.
Bike fit might be worth looking at. You won't probably notice issues doing a couple of 1 hour rides a week but if you are upping this to 6-10 hours then it will expose any issues you have. The other aspect I cannot stress enough, especially if you are in your 50s like me, is stretching and conditioning. 10 years ago all I needed to do was ride and ride. Now I have to be a lot more careful about recovery and muscle imbalances. It's dull but so worth it!
