So i've got a 4.8 year old car at 55k miles with a 1.2L puretech. It was only after I bought it I became aware of the infamous wetbelt system. I'm the second owner of the car having had it for about 1 year and a few months. Timing belt replacement is 6 years or 60k miles (although dealer actually put 64k miles on their ad). Car was ex motablity, so it should have been serviced for its first 3 years although there are no stamps to indicate that. I replaced the oil with manufacturer recommended, did all filters and general service 4 months ago.
Yesterday I was joining the motorway and got low oil pressure when getting to 4-5k rpm, the engine then refused to do much. Had to stop on the side of the slip, turn off and on again. After testing it seems this only comes up at high rpm. I can drive it normally with no errors as long as i keep rpms 3.5k ish and below. I have inspected the belt from the top and it is showing some cracking but couldn't see missing bits of belt. The underside was hard to see, i'm not sure if i'm imagining it but if i were to bet, i'd say it was shedding some bits as a week ago i put in some oil as it displayed low oil level and on the dip I saw some bits of black chunky bits. Low oil pressure at high rpm to me indicates either blockage with pickup tube (most likely given the infamity of wetbelts) or issue with the pump. I don't think its the sensor otherwise it would be displaying the issue all the time.
Here is my predicament, I do not know if the engine is getting enough oil even with the warning not trigger as i don't know what its threshold is. For personal reasons I cannot not use the car, which means i'll be putting miles on the engine while in this state and who knows how long its been partially blocked. Its still a guess since i can't confirm pickup tube is blocked, but how likely do you think the dealer/manufacturer will rectify it based on the infamous history of this engine/recalls/wetbelt garbage and the history of this particular car? As well as the fact that its seemingly "failed" (at least not a belt snap) before the recommended changing interval (which in itself has been a lowered revision from when the engine was initially released). I would have thought the change interval would be scoped to ensure these issues didn't happen? Clearly the wetbelt system is a design flaw, as they've now redesigned the engine with a chain.. It is easy for me to take off the oil tray and check/clean the pick tube but i don't want to destroy evidence as its booked in at a dealer for 2 weeks for "diagnoses". If theres no chance they'll do anything under a manufacturers warranty then i'd rather just drop the pan now, clear it out to hopefully get me by the next few weeks, save the diagnosis fee and book it in for a timing belt replacement. I'm just loathed to drive it for hundreds more miles when knowing its likely continuing to damage the engine (even if no faults show and i keep it low rpm)
TLDR: Have an oil pressue issue, think its the wetbelt. No time to wait for dealer or garage so confirmed pickup tube is blocked with belt, replaced belt myself here
forums.overclockers.co.uk
1.2L Puretech/wet belt issues
So i've got a 4.8 year old car at 55k miles with a 1.2L puretech. It was only after I bought it I became aware of the infamous wetbelt system. I'm the second owner of the car having had it for about 1 year and a few months. Timing belt replacement is 6 years or 60k miles (although dealer...
