Nah that's gambling.The default lifestyle fund is basically a tax on stupid people.
Only 39 so a way to go yet. My understanding is you potentially want the safer stuff later on unless you know what you're doing, which I don't.They'll 'lifestyle' you into more and more bonds as you get older and you'll miss out on a lot of growth IMO.
I had a look at mine today, still disappointing how little is in there and how much it is projected to be when I retire! Had a sniff around the funds (it’s managed by legal and general) there seem to be about 28 different funds it could be in but the whole lot has been in a new fund called ‘growth’ for the last which is only a year old so hard to compare over the longer term with the other funds, it is equity based and mostly US which seems sensible although I am tempted to diversify it and split between two similarly performing pots to hopefully a get a better long term average! The web portal seems intended to make it deliberately difficult to see how your money has been performing!
That seems to be the perceived wisdom yes, although with a target retirement fund I think you'll already have a proportion of bonds in the portfolio even though you are several decades from retirement.Only 39 so a way to go yet. My understanding is you potentially want the safer stuff later on unless you know what you're doing, which I don't.
Yep I think it's 20/80 split at the minute.That seems to be the perceived wisdom yes, although with a target retirement fund I think you'll already have a proportion of bonds in the portfolio even though you are several decades from retirement.
It comes down to peoples attitude to risk really, I'm still heavily in stocks even though I've retired, and plan to continue on that path for a few years yet, which I'm perfectly comfortable with.
My funds have averaged over 10 per cent per annum over the last 10 years. I track their performance every month and I only invest in global equity trackers. The default lifestyle fund is basically a tax on stupid people.
I'm sure L&G do their own Developed World tracker or Dev World exc. UK for something like 0.10 or 0.12% when I checked recently for a family member who was also in a retirement fund and moved it out the default to global equity. There was also an Islamic World tracker that's done very well and ESG world. Take a look to see if you can find these.
I'm curious if folk still opt for an annuity versus a drawdown, which seems to be a better method for a) ensuring maximum investment returns (assuming no catastrophic banking crashes), b) allowing money to be pulled as required and potentially better management of tax arrangements and c) ensuring all pension investments are accessible via beneficiary and retained within the estate after death.
Lifestyle is not a fund, it’s an investment plan/strategy…. You can have many different funds within a lifestyle plan.. my default one invests in funds that aren’t available in the open market.My funds have averaged over 10 per cent per annum over the last 10 years. I track their performance every month and I only invest in global equity trackers. The default lifestyle fund is basically a tax on stupid people.
Simple solution is just to extend the retirement date, so that they move you into safer investments at a later date and you have more time in the more risky investments.. fine if you have a means of supporting yourself for that period, like other pension pots and ISAs in case the market takes a tumble.They'll 'lifestyle' you into more and more bonds as you get older and you'll miss out on a lot of growth IMO.
I noticed the Islamic fun seemed to have performed exceptionally over the last 5 years, it has slightly higher fees but if it maintained its performance it would more than make up for that. The generic growth fund I’m in is all equities and mostly US and the performance over the last year since they set it up is pretty good compared to the rest of the funds. Think I need to split my pot a bit just to balance my risk v’s growthI'm sure L&G do their own Developed World tracker or Dev World exc. UK for something like 0.10 or 0.12% when I checked recently for a family member who was also in a retirement fund and moved it out the default to global equity. There was also an Islamic World tracker that's done very well and ESG world. Take a look to see if you can find these.
It's not a straight forward decision.
Annuity will tend to pay a higher rate than a drawdown as the risk is averaged. You have to assume you live for 30-40 years and limit the drawdown while the insurance company can plan an average of 25 years across a big pool.
You also have some certainty, if stocks drop 30% one year and take a while to recover, a real possibility over 30+ years you could burn the pot a lot faster.
Returns are averaged which is fine when saving but a risk when you need to draw and pay the bills.
Back calculating a 4% drawdown fails over a high percentage of history wheras currently you can get 4.2% with 3% annual increase and 50% partner at 60 or 4.9% same terms at 65.
I'm not there for a while yet, but would consider a split if in good health. Convert part to an annuity, sufficient for the basics then leave the rest to grow and call off as needed.
I think a global tracker would be better, set and forget. Lifestrategy funds are heavily biased to their home market.Would something like the LifeStrategy® 100% Equity Fund be better than the target retirement fund then.
I certainly don't know enough to pick my own funds individually.
Personally I have LifeStrategy 60 and 80, for the simple reason in case the stock market goes belly up and I will still have some bonds.Would something like the LifeStrategy® 100% Equity Fund be better than the target retirement fund then.
| Name | YTD Return (%) | 1 Year Annualised (%) | 3 Years Annualised (%) | 5 Years Annualised (%) | 10 Years Annualised (%) | |
| Check-box for table item | Vanguard LifeStrategy 100% Equity Fund A Acc | 5.71 | 19.09 | 9.00 | 9.87 | 10.32 |
| Check-box for table item | Vanguard LifeStrategy 80% Equity Fund A Acc | 4.36 | 15.34 | 6.11 | 7.59 | 8.50 |
| Check-box for table item | Vanguard LifeStrategy 60% Equity Fund A Acc | 2.99 | 11.65 | 3.31 | 5.31 | 6.68 |
| Check-box for table item | Vanguard LifeStrategy 40% Equity Fund A Acc | 1.49 | 7.88 | 0.57 | 3.01 | 4.81 |
| Check-box for table item | Vanguard LifeStrategy 20% Equity Fund A Gross Acc | 0.05 | 4.69 | −1.90 | 0.90 | 3.04 |
The bonds will still give me a fixed return over the period till the stock market recovers.The stock market goes belly up and, you will still have some bonds, and then what?
