This was neat.
Not $60k neat, but neat.
Thanks Sundara are ordered and a balanced cable to go with it. Hopefully the cable and headphones are reliable and issue free. I’ll report back and let you know when I receive themSundaras are in another league to the DT990, even the 600 ohm variant. The only downside is reliability and build quality, Beyers are way better built and last decades. If you are ok with the poorer build quality and prepared to run the gauntlet of reliability, the Sundaras sound a LOT better than the DT990.
You can't connect DT990's balanced without rewiring the headphones.
If you want a Beyerdynamic headphone the DT880 is a better bet, specially the 600 ohm version. It's a semi-open/closed headphone as opposed to fully open backed for the DT990 and Sundara.
Just added a sparkly new pair of Sennheiser HD800S to the stable, so the (not even) full list is now:
Sennheiser HD800S
Sennheiser HD650
Grado RS-1x
Grado SR325x
Denon AH-D7200
Beyerdynamic DT1990 pro
Beyerdynamic DT990 pro
HiFiMAN HE400i
Sony MDR-1A
AKG K702 (bass port modded)
plus numerous sub £100 IEMs (I find them too uncomfortable to spend serious money on)
I got them from Audio Affair for £1099, so £400 off - it was what made me finally cave in and order them. So glad I did, they are insanely good and work really well for all the genres I listen to.Enjoy! I love the HD800S, now it's available for only around 1k it has to be one of the best price to performance headphones at the higher end, it's one of those headphones that competes with nearly everything at a higher price point.
As per the helpful advice from @Things change I've changed I've finally got a balanced cable for the HD 650s. From Sky Audio Cables. Also added the 4.4 bal to 6.3/3.5mm adaptor. In teal and anthracite. The cable is lovely, such high quality and well made. I also now understand balanced, in that letting the HD 650 use 4.4mm balanced output from the Fiio K11 really opens it up. Still need the final 4.4mm to 2.5mm adaptor for the Qudelix - unfortunately Sky Audio Cables don't appear to make those.
LATE EDIT: Scratch that. Sky Audio Cables have offered to make a 4.4mm Bal to 2.5mm Bal cable to match the 4.4 to 3.5/6.3 cable. Woot! Top service, so final
Received my XLR balanced from Skyaudiocables last week, great quality, will be looking at some custom XLR interconnects in the not so distant future from them.
Such nice cables. Got my custom 4.4 to 2.5 balanced adaptor today. Cannot speak highly enough of the service and quality.
That was nice of them to do that, I need to throw some more money their way!
