I think the true solution is far far harsher punishments, particular when it involves a breaking and entering someone's home, at this point the punishment should be several years jail time.
There should also be no punishment if a home owner kills an intruder, end of the day I thought I saw a pointy shiny thing in the hand of the burglar/thief, I panicked and I defended myself and my family from an intruder, I of course asked them to leave nicely first.
My view is either make it easy, so keys easily visible so if the worse happens, someone breaks in they don't appear in your bedroom at 3am threatening you.
Or make it more difficult which there are many things you can try:
- Cars not on show to general public, parked out of view or garaged if possible.
- Keys in a faraday box out of view
- Physical security items on car, steering lock, clamp etc. though their effectiveness is not much it is a deterrent and the thief is more likely to just go find a similar unprotected car elsewhere
- Gate your property if possible
- Install Ring/CCTV around the property, further deterrent.
- Enable your cars tracker if it has it, so install / download the APP as most modern cars have one now or install a fancy tracker system
- Maybe get something like a Ghost or a fancy immobiliser
- Install an OBD lock or hack your OBD port or remove it.
- Install a fuel pump kill switch.
There is quite a bit you can do, even more so if your an OK mechanic, sometimes some of the simplest items such as disconnecting the battery will leave most modern thieves stumped and as they are in a rush they are not going to try and diagnose why your car has no power or the OBD port is not working or the car is not firing up......
Totally depends what your mindset is, make it easy and just pay more insurance.
Or take the risk someone might break in and confront you.
I personally am in latter camp, but I am fortunate we live rural with no passing traffic and it is very easy for me to see if I am been followed, secondly cars are parked out of view around rear of house and more expensive stuff in locked garages and anything on show outside has steering lock fitted, is under cameras and on a gated driveway, the house is also alarmed.
In short if anyone broke in the entire neighbourhood would be awake as the house alarm is bloody loud but I also have separate sirens I can active from my phone as well and one would hope with all the noise they'd leg it but fingers crossed it never gets to that stage. No idea how I'd react to be honest, either throw keys at them or grab something and attack them, I just hope to never be in a position to find out, but saying that I am certainly not going to make their life easy. If it was legal to have a gun, defend my house I personally don't feel I'd have any issues shooting an intruder and killing them, not sure that makes me a bad person but I'd just feel I was doing the world a favour by saving someone else from these scumbags.
