Hi All,
Finished upgrading from my 5800x / MSI B550M Mortar combo to a 7950X3D and Asus X670E-A - The difference is a lot more than I was expecting, especially in games!
Now its all up and running (basic setup, EXPO I set up in BIOS running 32gb DDR5 6400 CL32 - No problems with booting at all) - I decided to enable PBO and was then going to tune the CO for each core, however, even though in Ryzen master its showing max boost of 5900 mhz on the Freq caores, it never actually gets there, stays at 5750 in HWMonitor.
I've tried changing PBO in both the Main ASUS menu and also the "AMD Overclocking" menu (for some reason the same settings are listed twice in two different areas) under advanced in the BIOS.
Any ideas?, I did read that PBO wont work unless you have CO set also, so set a quick "all core" -10 - Fully watercooled system (7900XTX, 2 x 360mm rads) CPU temp doesnt go higher than 71oC in stress tests.
Any insight would be welcome.
