Just spotted the protect upgrade announcement: https://community.ui.com/releases/U...n-3-0-22/160b97cc-13e5-4d90-b270-1d2d1119a349
I've got a 2nd gen PoE 16 port which is a good bit shorter in depth compared to the UDMP. I've been eyeing up the Excel Environ WR390. Compact enough and with enough internal working space for a UDMP with a angled power supply cable.One word of advice with these UniFi switches depending on the model you go with they can be quite deep, as I run a 600mm cabinet and that gives just about enough space behind for UNVRs / Enterprise switches etc...
I think their cabling was the first thing I used then bought a patch panel which was decent also plus the keystones.I rate Excel items quite well, as I use Excel cabling, jacks and keystones and never had an issue with them.
If I am honest, I nearly ordered the U6+ earlier, at £95 from Amazon it looked tempting, but the U7 Pro is only a few quid more and brings more to the table. Previously I was able to cover three floors just about with a single AC Pro, so it feels like a reasonable choice.@Avalon you should get a UniFi AP and run Private Pre-Shared Keys. Glad you are at least somewhat liking it, I did say that they've come on leaps and bounds recently, but still many improvements to be made and will no doubt be coming.
so its working right now, but im not 100 confident as it had dropped connection before.not sure if this the right place but im hoping someone can help.
received my cloud gateway ultra this week, so had time to set it up today. just replaced my working UX.
but once its booted up the screen shows 'plug in cable', picture pointing to the wan port.
its all connected the same, light is on the wan port when i plug it in, modem is fine, also tried different cables, tried reboot and factory reset with no joy.
unifi app wont connect to the UCG either, it says bluetooth connection failed.
any suggestions?
