Hi noob question I'm sure, but sometimes it won't let me equip my booster, only strategems, what's the reason?
As it gets less confusing it will get more chaotic4 hours in and I gotta be honest I have no idea what I'm doing. I don't understand the objectives and have no idea where they are on the map so i just follow others. I also find the UI very confusing.
Other than that shooting bugs is very fun
It usually means another player in your squad already chose that booster. Pick another (if you have one) as all boosters apply to all team members.
Main objectives are marked in orange, these need completing before you can extract.4 hours in and I gotta be honest I have no idea what I'm doing. I don't understand the objectives and have no idea where they are on the map so i just follow others. I also find the UI very confusing.
Anyone else use napalm strike? Looks good but only two uses before rearming
Orbital laser and either 500Kg or precision strike are my go to, IMO the ones which only kill smaller stuff are a bit of a waste of a slot and many of the others have a much higher chance of team kills.
lots of talk of crashes etc... Weirdly I dont think ive had a single crash or disconnect in some 20 hours on this. Must be lucky!
Small update released supposedly fixes the crashes with Arc weapons - but from what I've experienced they don't seem to be the only cause of the crashes since last patch.
Last patch just under a week ago introduced a lot of crashes, personally didn't have many before that aside from finding the game unstable at high frame rates on some of my systems (not an issue with those systems).
Same, I have just hit 44 and nearly 45, still got a fair amount of stuff to buy using the medals for weapons etc.There has been issues NGL, but for most of it its been acceptable. Almost level 50 so plenty of hours, looking forward to more content.
