House was built around 1900.
This wall is the gable end of the house.
Floor is timber, suspended.
DPC is around 6 years old.
It is a cavity wall.
No cavity insulation.
Has cavity ties.
House was repointed approx 9 months ago.
Sofits and fascias were replaced around the same time.
House was damp when we bought it, and it had a lot of the ground floor knocked back to brick around 1m up and then replastered in lime plaster. This wall was not done.
The damp spots on these walls predates any recent work that was done on the house. I wanted the pointing done before reviewing them as there's little point re-plastering if there's water getting in through the exterior bricks.
Can see in the hallway there is a large patch that spams from the window. A second, smaller patch futher down, and theres another near the front door.
In the foreground - you can see there's a damp patch in the corner of the dining room. This one is most visible when the weather is humid. I had some people look at this a couple of years ago, and they couldn't see any reasson for it. Suspected it might be a cold spot caused by cavity wall ties.
In the corner, the wall gets damp. There are water marks on the wall further up and near the radiator.
Exterior, looking towards the back of the house.
and then looking at the edge of the window, where the big damp area is in the hallway
Chatting with the guys who did the pointing, they couldn't see any issues where previously letting water in.
I realise I'm going to have to get people in to look at this, and likely replaster the entire wall as once it's wet.. it's wet - but just wondering if there's anything glaring going on that I've missed.
Has cavity ties.
