Hey,
Recently got a 4080 Super Zotac OC white, while the card runs great it had terrible coil whine so has been returned and purchased another but the whine is exactly the same..
Is this common on the 40 series or have I just been unlucky and try a 3rd time?
Hey,
Nope, sounds like bull****.but I also remember somewhere reading that its larger cache somewhat mitigates this by tapping into system memory more efficiently?
This 100%. Many special people say "no coil whine" - but have a card that screams like a pig to someone with some hearing left.Saying whether or not your card has coil whine is pointless unless you also give your age - your ability to hear it diminishes with time!
Either that, or they're using a 4090 @ 1080P with Windows 7, on a 60hz monitor (there are people in this scenario on this forum) - where GPU utilisation doesn't get close to 100%, so the card is nice and quiet.
Do they just like buying Jensen jackets? I don't get itEither that, or they're using a 4090 @ 1080P with Windows 7, on a 60hz monitor (there are people in this scenario on this forum) - where GPU utilisation doesn't get close to 100%, so the card is nice and quiet.
So far as I know, the cache in modern cards (e.g. RDNA2, Ada) is primarily used to mitigate the performance loss of shrinking the bus (e.g. 4060 Ti has a bus that is half the size of the 3060 Ti). The more data you can fit in the cache, the less it has to use significantly slower dram. How much that helps with performance, I don't know, but I'm pretty sure it won't help when you run out of memory.Had to buy the hated 4060ti today for my son. I know it’s got a lot of bad press for only having 8gb vram, but I also remember somewhere reading that its larger cache somewhat mitigates this by tapping into system memory more efficiently?
Anyone know how true that is or have I completely made that up?
What other GPU's are you comparing it to?Thanks everyone, sounds like I may have just been unlucky, this is the first time I’ve ever had coil whine on any gpu.
Guess we’ll try a 3rd time!
PSU can also cause coilwhine on GPU's.
It gets disregarded.
I haven't heard coil whine since the 2070 Super really. 3080 ti FE had some minor but only in some display resolutions/conditions. 4090 has none, although on a new PSU for that.
Previous was a 2080ti.What other GPU's are you comparing it to?
Higher the power draw of the GPU means louder coilwhine.
It’s on any game / benchmarking.What games and at what FPS?
Coil whine is usually worse at very high FPS.
