Federal bank or reserve or the same.You'd think a loan then in that case, rather than actually footing the bill.
My main interest is in the ship's maintenance.
When the power went out, there were no external emergency lights to be seen. I'd have thought that if a ship suffered a total loss of power, that several battery systems would come online and light it up to prevent other vessels at sea crashing in to it, and if it suffered a breach, to light up the path to the lifeboats. Yet it just went totally dark, like a ghost ship. Going by the power repeatedly coming on and off in the short clip we've seen, it's possible that this ship was struggling for some time and that the ATS couldn't take it any more and packed up.
I'd also like to know how a ship of this size managed to get itself in to this situation in the first place. The amount of safety and alarm systems in place to prevent this exact type of scenario taking place would have had to be immense, unless it's a 40 year old 3rd world vessel running on 10p coins. That captain's deck will likely have lit up like a Christmas tree several times before getting to this point. And I don't mean in the last few minutes, I mean the last few days, if not weeks.
The investigation is certainly going to be interesting, I suspect we're going to see a company cutting corners, ignoring engineers, and forcing their staff to continue sailing despite the obvious warnings.
100-200 thousand tons of ship.
You're going to need protection piers that are absolutely massive to have a hope of stopping it, and you're going to need them all around the supports, which means you've now cut down the usable channel for the ships very significantly.
You hit a certain size of ship/truck/train or whatever where any options for "stopping" it become infeasible, for reasons that go from "it won't stop it" to "it's going to cause bigger problems than it solves".
Speculation, what if it was fire related or some sort of explosion. Something that delay/prevent back up systems kicking in properly.You are correct in that there should be lighting and various other systems on UPS (uninteruptsble power supply) batteries which should stay on, then an emergency generator should kick in to power various other systems after a set period of time. I can't remember the exact details off the top of my head but there's a lot of regulation about this sort of stuff and it all has to be tested regularly.
In terms of advance warning, not really. I was on a ship where we lost power and it came pretty much out of the blue. A gasket failed on a steam line that happened to be located in the same room as a lot of critical electrical components. Didn't know that was going to happen until all the smoke alarms in the space started to go off as the room filled with steam. That was a fun evening. Luckily we were in the open sea in good weather but if we had been in the same place as that container ship then something similar could've happened.
You'd be amazed how often thing go wrong on ship, just mostly it happens far from land and so there are no real consequences. Unfortunately when there are consequences, they tend to be big.
I think deflecting would be just as hard if not harder, since you don’t know the direction of travel.You don't need to stop it you just need to deflect it, various bridges do actually have this sort of protection and in the case of the Baltimore bridge there appear to be some other poles in the water in front of the bridge that are protected, sadly the bridge itself isn't.
“Chief, what does this breaker d-“
You need to know the direction of travel because with that you can calculate the angle of impact.You don't need to know the direction of travel (though you'd have a reasonable idea from both directions) it's still easier (requires less force) than stopping it.
Seen that before too!
They are footing the bill to get it rebuilt faster, the shipping company insurance will still have to pay out but that takes ages and may be years of litigation.
The private companies are going to be licking their lips to get this contract to rebuild the bridge. All the cows at once have come home to be milked.
Well the bridge stopped it?So many expert structural engineers on this thread.....
oh and the MV Dali was fully loaded with over 9000 containers (over 100,000 tons) and was leaving the Port to head to Sri Lanka; energy of the impact is a straightforward mass x velocity
