What if the tug loses power like the ship did?
Not saying its a bad idea, it is sensible, how do you mitigate against all possible scenarios.
Is that the same as having a very keen side piece?Something I've also encountered, we had a standby tug.
Just a smidge, shoulda said the largest container ship in the world was 29,000 tonnesI think your a little out there....
So you're one of the lovely folk I get to chat to in a couple years time...From the Institution of Structural Engineers:
IStructE believes that ongoing risk assessment of structures is critical. Investigators will review the pier design and changes to vessel impact protection devices to determine potential shortfalls in risk management.
Bridge expert Ian Firth, independent consultant, IStructE’s past-President and a Fellow comments as follows:
“It is almost impossible to design a bridge pier to withstand this kind of impact. Therefore, we tend to design impact protection measures to prevent it from happening instead."
“Dolphins or other vessel impact protection devices in the water are commonplace since the Sunshine Skyway collapse in 1980. But this bridge was built in the 1970’s, so the design would not have incorporated these devices at that time. The fact that a vessel can veer off course and hit the pier is the reason to design vessel impact protection systems so that a large vessel cannot hit the critical bridge support."
“The footage shows there are small dolphins, (the small round objects visible in the film), each side of the bridge piers - these have not prevented the vessel hitting the pier.
“A new bridge design would probably be a cable stayed bridge with a much larger span, moving the supports well away from the navigation channel and into shallower water.”
IStructE also considers that a full investigation will have to address many aspects of why this happened, asking questions such as:
- There are navigational rules for ships, why was this vessel out of its channel?
- Bridge piers are normally protected from impact, so what exactly was the pier design?
- Are the codes and regulations sufficient for today’s increasingly larger cargo ships?
- Are further measures required to ensure this does not happen again?
Interestingly I was interviewing candidates this morning on behalf Institution of Civil Engineers, for them to join as Chartered Members, and one of them is a long-span bridge designer. The bridge he focussed his presentation on was a cable stayed bridge with a much larger span indeed, with the supports being away from the sides of the river it was crossing (not just to avoid collisions though).
“I would have expected to see a system of ‘dolphins’ and/or fendering, adequately secured into the river bed. Such a system would be aligned on both sides of each main pier with the purpose of deflecting errant vessels from collision with the piers. Collision protection would generally be designed to resist glancing or sideways impact forces, much less than from head-on impacts. Other measures would comprise warning systems including navigation lights etc.
Actually think he raises some good points, the other poster is just being deliberately condescending.and another thread begins to disappear down the dowie hole......yay
They''ll never build a tunnel big enough for a ship like that silly.Build a tunnel.
i am going to be condescending when someone ignores what I wrote in my post then repeats it back to me like they just discovered it, yet somehow believe I’m not going to notice.Actually think he raises some good points, the other poster is just being deliberately condescending.
There were at least 2 sections that collapsed in the centre, split by supports. One section collapsed directly because the support had been hit. But when that went down it pulled another support down, which took down the other section.It didn't did it? The centre section collapsed. A lot of the bridge is still intact.
Am I right in thinking that tugs, while extremely powerful, aren’t very fast by large ship standards?Something I've also encountered, we had a standby tug.
Basically all the bridge part of the bridge collapsedThere were at least 2 sections that collapsed in the centre, split by supports. One section collapsed directly because the support had been hit. But when that went down it pulled another support down, which took down the other section.
It shows the section support collapse in that video.
You don't need to stop it you just need to deflect it, various bridges do actually have this sort of protection and in the case of the Baltimore bridge there appear to be some other poles in the water in front of the bridge that are protected, sadly the bridge itself isn't.
I think deflecting would be just as hard if not harder, since you don’t know the direction of travel.
You don't need to know the direction of travel (though you'd have a reasonable idea from both directions) it's still easier (requires less force) than stopping it.
Ian Firth, independent consultant, Fellow and past president of the Institution of Structural Engineers, said:
				Sherif El-Tawil, a University of Michigan engineering professor, said there are several safety measures that “would have made a huge difference” had they been in place Tuesday morning when a cargo ship plowed into the bridge and caused its collapse.
El-Tawil said a fendering system may have softened the 985-foot-long ship's blow. Pilings anchored to the river bottom, known as dolphins, are another measure that could have helped to deflect the container ship Dali.
I said “just as hard if not harder”. The harder bit was in reference to extreme conditions were you’re expecting to absorb a significant amount of kinetic energy but must transfer the kinetic energy back to the ship to change its velocity so that you can “deflect the ship” or whatever you actually meant by that statement.
Dowie has got my point already. At this point I’m giving him fetch quests since he wants to pointlessly argue.
Deflection is common practice usually but I guess at the time the bridge was built wasn't considered or omitted? All the bridges in London are built to deflect.
That said should any large vessel hit the deflection structures a full structural inspection of the bridge will have to take place regardless. Many of the ones in London are now monitored with various sensors to monitor movements, stresses and strains over time.
Prevention however is better than cure. In my opinion 2 things failed here. 1 not having a tug boat for such a large vessel in that area with many obstacles, and lack of protection for the structures.
So the remaining structure that has the road intact on struts over the river is what?Basically all the bridge part of the bridge collapsed
They're ramp sections with much smaller spans, the actual bridge part i.e the girder structure collapsed entirely.So the remaining structure that has the road intact on struts over the river is what?
