- 8 Nov 2006
- Scotland
They all should and mine does at stock after a fresh Windows 11 install. It didn't on my 2.5 year old install which started out life on a different motherboard and CPU. The only reason why I did a fresh install was because Geekbench V6 was showing a much lower score than normal 13000 as opposed to 20000 which I now get.
I only tested OCCT again for the hell of it and it passed. In future when changing motherboards I will do a fresh install, it only took me about 4 hours to reinstall everything which is not to bad if only doing every few years.
Never realised that transferring an old Windows install to new hardware would cause this issues. But the advice has always been, do a fresh install after changing hardware.
Yeah, 100% recommend a new install of Windows when it comes to these cache CPUs, far too much can get misconfigured in the passover, especially with old drivers/configs.
In general a new install is a good idea even with a motherboard change, but it's even more crucial with CPUs, especially if you're going to these 2 CCD 7950x3D's which do a lot of voodoo on the software end to try and juggle which CCD to prioritize depending on what is running in Windows.
