I bought my Synology DS-1019+ a couple of years ago and although it's worked perfectly, I've always been a little miffed as to how loud it is.  Not the drives spinning, accessing or the fans but just a general vibrating buzz type of noise.  If I put pressure on the case, the noise would reduce or change.  It's always been there, some days it was louder than others.  I've got it on a foam bed with noise cancelling feet and extra pads.  None of these really made any difference.
Yesterday, I shut it down, removed all the caddies one by one and put pads of sticky velcro (the soft side, not the hard rings) along the side runners and also inside the caddy in a couple of places where the drive touches the plastic.
Here it is on the side runners.
On the inside of the drive caddy.
When I powered the NAS back up, I could instantly tell that it's better. I can still hear the drives spinning quietly and the access sounds but the vibration and buzz appears to have gone completely. It's so different, so much better.
I can't claim responsibility for this, I found it somewhere on line and I thought it worth sharing here.
If you've got a Synology (or probably any NAS) with hard drive vibration sound, this is a really simple, easy, cheap solution.
