Made another one, this time it squirted towards the water tank...sour again.
I am doing something wrong somewhere.....
Have you knocked the pf as you put it in the group head?
The elektra is like this - anything wrong and the lever spring will punish you
in the spring we believe and it
shall punisheth deviation from perfection (gush/sulk etc)
Check grind consistency and distribution before tamping. Tamping is not a solution to uneven prep. Also the tamp should be tight but not vacuum tight as it will lift the puck grains causing channels.
The elektra also requires the oils to prevent it from gushing and as hard as you try, tamping will not solve that - are your grinds getting too hot in the grinder?
Sour is also when the puck is too cold and the water is possibly being cooled by a cold group head.
You’ve guessed it - the elektra will also punish you for not warming the grouphead/pf with sour coffee.. the second coffee is usually sweet and balanced, and the third/fourth is usually starting to get tones of bitter if the group head heat is not managed.
How long is the machine on before matters but I suspect you have a PID managing the temperature.
Too finer grind, with a hard tamp and fresh roast ..and the elektra lever will sit there and no water gets through the puck.. there’s two options - first leave to get cold, several hours, leaver down and then undo the pf. This way there’s no boiler pressure when you push the lever ans it then allows the pressure to be eased off..
The other option is the hot option.. wrap a towel around the gh and pf joint, and a stacked towel shock absorber underneath. The mummy wrapped pf is now ready.. gently turn the pf to disengage.. following the mild explosion, the scalding steam and coffee bean mix should be absorbed by the towels.. and you hope there’s no gap..
Everyone needs an elektra in their life at some point.. it’s like an italian girlfriend.. you learn fast, forgive the quirks and enjoy the beautiful coffee.
