- 25 Mar 2004
- Fareham
The dodge roll only seems useful when the enemy flashes blue ? Saying that, I’m sure you’re invincible when you dodge roll and turn red while doing so.. not sure
Blue means you need to blink when your sword flashes blue, so dodge + forward which blinks behind the enemy.
Purple means you need to dodge + backwards.
You can perfect dodge any attack you want as well, like the rocks he chucks at you, or the charge he does at the start. If you hold triangle after a perfect dodge you teleport in front of the enemy and deal a heavy attack/minor stun, this doesn't share cooldown with your usual rush (hold triangle) ability. This is a skill which you don't start with though, but it's in the challenge mode as more stuff is unlocked there.
For standard perfect dodge I do find not using a direction and holding dodge feels better. But generally speaking if not having to dodge, I think I'd usually just parry.
