I used balena etcher for all my flashing ad cards so far on macos.What software do you use to flash it with?
rp2000
MuOS takes 7 seconds to boot on mine, where as Batocera is 27 secs!Im running this on my plus, boot time is a little slow and Dreamcast is garbage due to no Flycast Xtreme core but apart from that it's great.
MuOS is much snappier at booting and loading, but still not a patch on Garlic 1.4.9 on the OG RG35XX.
It's got the installation instruction on the github page - pretty easy, just flash the card, boot then take it out and copy your bios and roms to it.
Even has built in scraper for art.
Big difference, but being a total noob to all this retro handheld stuff 27 does not feel like a lot to me!
I could only get this to work by creating an account on screenscraper. The other 3 "free" options barely scrape 5% of my library, whereas screenscraper gets 100%.
Did you use the same method?
rp2000
What theme are you running, looks good.Garlic is the best
About 20 mins for 232 items. No fan-art, videos and other crap. Just 2d box art and title screens iirc.How long did it take for you to scrape your library? (I know this is almost a "how long is a piece of string question!")
Yeh, just the free ones. My library isnt huge but I just left it to scrape, didnt take too long.MuOS takes 7 seconds to boot on mine, where as Batocera is 27 secs!
rp2000
Custom made - a mashup of Black Seraph default, someone elses icons and me changing a few things like font and stuff. Happy to share it if you want to try.What theme are you running, looks good.
I just signed up for their Patreon, I haven't hit the limit but it's so good it's worth £1 a month to support them.Left it to scrape overnight, but it seems Screenscraper doesn't have PS1 or Mega Drive games, not sure why those are empty.
edit - hit the daily cap limit for free account!
Okay, finished scraping! Took a while!
But some systems do not work at all....I have the bios...I literally copy them from my Miyoo Mini's Bios folder across.
It goes into the Share Drive /bios folder right? Not with the games folder.
Also, can you have too many cores? or is there a way to get the console to point it to the core you want?
Edit - PSX started to work after reboot....weird! (though it still says it is missing cores though) Dreamcast refuses to work though, i have the right cores...
I got DC to work anyway. Performance is not 60fps out of the box for Daytona USA 2. SFA3 is OK, but it's 2D. Sega Rally crashes. Crazy Taxi is choppy.I definitely have the correct bios...like there are 3 for Dreamcast, all 3 are in the bios folder but Bios check says 2 of them are missing.....weird!
You have to force the "Libretro FlycastVL" core. When set to auto it uses "Flycast" which seems to crash most of the content.Crazy Taxi won’t even load for me….i don’t know what I’m doing wrong
Be interested to hear how the Saturn emulation is.I got DC to work anyway. Performance is not 60fps out of the box for Daytona USA 2. SFA3 is OK, but it's 2D. Sega Rally crashes. Crazy Taxi is choppy.
I got a libreto BIOS pack and the ones from that I tried work fine on both my desktop and rg35xxh installs of batocera.
I'm gonna try Saturn next as thats Gen 5 so should be solid performance, has Daytona as well!
rp2000
You missed my edit:Be interested to hear how the Saturn emulation is.
