Yeah it was £20 or so more expensive than Unifi directly but its in stock!
Just FYI they included Unifi USB C PSUs for UK plugs, so I'm returning the Pi PSUs that are yet to be delivered.
Can anyone help me on how I can do the following if possible.
Using a unifi dream machine, how I can block all apart from youtube on a wifi connection.
For easiest management you need to create a network for the WiFi traffic,
Then in Security - Traffic and firewall rules could just follow the simple format, Allow APP, YouTube, to the WIFI network then another rule to Block All. I'm not sure how UniFi grades these rules but you might have to do the Block All then the Allow YouTube, a proper firewall you'd Block then allow.
Thanks. I've tried Block all App Groups, allow YouTube but it still allows access to various websites.
| PoE interface | (7) PoE/PoE+ (Pins 1, 2+; 3, 6-) (1) PoE++ (Pair A 1, 2+; 3, 6-) (Pair B 4, 5+; 7, ![]() |
| Total non-blocking throughput | 8 Gbps |
| Switching capacity | 16 Gbps |
| Power method | (1) 54V, 3.9A power adapter (Included) PoE++ (Pins 1, 2+; 3, 6- and 4, 5+; 7, ![]() |
| Power supply | 54V, external, 3.9A/210W |
| Supported voltage range | 44—57V DC |
| Max. power consumption | 9W with PoE input (Excluding PoE output) 8W with AC adapter input (Excluding PoE output) |
| Total available PoE | PoE++ input: 42W PoE+ input: 16W 60W PoE adapter input: 42W 60W AC adapter input: 52W 210W AC adapter input: 202W* *At 45° C (113° F) operating temperature. Reduced to 161W (230V) or 121W (115V) at 60° C (140° F) |
| Max. PoE+ wattage per port by PSE | 30W |
| Button | Factory reset |
| Ambient operating temperature | PoE++ input: -30 to 60° C (-22 to 140° F) 60W AC adapter input: -20 to 45° C (-4 to 113° F) 210W AC adapter input: -20 to 60° C (-4 to 140° F) |
Could someone just confirm I am reading this correctly?
If I brought a USW-Ultra-210W (202W) 8 port, and I paired it with two Reolink 4k RLC-830A cameras, there would be enough power to the ports, as it stats 48v active for the cameras, so this would only work on one port with that switch under the POE++ ?
as it states POE+ is max at 30w?
PoE interface (7) PoE/PoE+ (Pins 1, 2+; 3, 6-)
(1) PoE++ (Pair A 1, 2+; 3, 6-) (Pair B 4, 5+; 7,Total non-blocking throughput 8 Gbps Switching capacity 16 Gbps Power method (1) 54V, 3.9A power adapter (Included)
PoE++ (Pins 1, 2+; 3, 6- and 4, 5+; 7,Power supply 54V, external, 3.9A/210W Supported voltage range 44—57V DC Max. power consumption 9W with PoE input (Excluding PoE output)
8W with AC adapter input (Excluding PoE output)Total available PoE PoE++ input: 42W
PoE+ input: 16W
*At 45° C (113° F) operating temperature. Reduced to 161W (230V) or 121W (115V) at 60° C (140° F)Max. PoE+ wattage per port by PSE 30W Button Factory reset Ambient operating temperature PoE++ input: -30 to 60° C (-22 to 140° F)
ok, great thanks, so all good[Official] Reolink RLC-830A | 4K PoE PT Outdoor Security Camera with Auto Tracking
Reolink RLC-830A is a 4K 8MP PoE PT outdoor security camera. Coming with auto tracking and person/vehicle/animal detection, color night vision, two-way audio, etc, it ensures your home day and night. Easy to install and use.reolink.com
802.3af so its 15w or so max but it will probably only use 8watts
Cloud Gateway Ultra now available via UI
This is what annoys me about the way they drip things over days/weeks/months, I want to buy what suits my needs best, if I don't know what my options are, that leads to buyers remorse, resentment and potentially returns when something more suitable pops up a week laterI should have waited
I got my order in before it went OOS, I guess it will ship Monday for Tuesday delivery. The Express I have will then go into AP mode as I find the Express just a bit slow and I like the dual WAN on the Ultra.
have been using UX as ap for about 3 weeks, does the job, was just way to slow compared to the UCG.Express I have at a family member is also getting changed to AP mode.
