Been looking at the sage dose control at £118 currently. Would prefer cheaper if there’s a gem out there that performs above its price grade!
I have a sage bambino plus machine fyi
Any suggestions?
For the price, hard to beat tbf.
Don't go in the espresso thread, it will cost you moneyAny suggestions?
I have a Eureka Mignon grinder and was happy to spend almost £300 on it. May be better options now but the was the single biggest element of overall espresso prep.
I think for price/performance the Sage is a good choice but depending on how into it you want to get (occasional drink versus all-consuming hobby), you’re at the lower end and may want to upgrade. FWIW I almost bought one of those too but I wanted to invest in something a bit higher end and more repairable. Just my experience, you may be very happy with the Sage.
I’m actually more keen on buying a cheaper model if they have good reviews, like what you mention. There’s a few on Amazon that seem to read well and my coffee intake isn’t at the addict level of some so could probably survive fine with something basicI bought a grinder on Amazon years ago imported from Germany, was cheap like £40 still going.
Only criticism is really loud, and getting fine adjustments on grind amount is pretty fiddly.
Edit: this one.
SEVERIN Grinder coffee grinder with electric grinder (100 W, stainless steel disc grinder, max. capacity 150 g) black/silver, KM 3874 https://amzn.eu/d/iezOt3B
That's inflation for you I paid about £40
Been using this since November, grinds down to espresso surprisingly well, I use it at setting 5 for my espressos. Price hasn't risen much since I bought it.
SHARDOR Conical Burr Coffee Grinder Electric, 31 Precise Grind Settings Coffee Bean Grinder for Espresso/Drip/Pour Over/Cold Brew/French Press, LCD Screen and Precise Digital Timer, Black https://amzn.eu/d/90nD2BZ
I went for the smaller of the two, still holds around 250g of beans should you want to grind enough for a trip away etc. the container holds around a third of that but I don't store any coffee in it. Either straight to portafilter or sealed container.
I have mine dialled in at 5 for my espresso, honestly can't fault it, it's not overly fast or slow, uniform grind, static is there but low, easily better than my old krups burr grinder.@brendy So far so good with this grinder, makes me wonder why the Wilfa is £35 more.
Still haven't heard from the seller regarding my broken Wilfa.
