Hello
I'm finally dipping my toe into surround sound with my AVR-X2400H. I bought x2 Cambridge Audio MIN22 satellite speakers to go to the sides. Up front I have my Triangle Borea BR08 floorstanding speakers. I don't have much room and I nearly went for the KEF T101 speakers but I think the Cambridge Audio satellites will perform better.
I've been reading the manual to see what I need to change on the Amp and I'm confused.
This is the setup I'm aiming for - minus the sub and center.
And that diagram is accessed from the top line of this amp assign table (link not shown).
It says "Can be set in all Amp Assign modes". What does that mean? Because, if I look at the Amp Assign modes, I can't see a 5.1 entry that relates to it.
I thought maybe just leave it at ZONE2 (Default)? But then the diagram looks like this according to the manual.
Any ideas? Or is that safe to use?
Once that is sorted I think I'm OK, I know I need to re-run Audyssey setup which is easy enough to do.
Oh, what sound mode would I then pick? Just set it back to "Auto" or should I manually set it to "Dolby Surround"? At the moment I have it set manually to "Stereo" as when it was on "Auto" it was choosing surrond modes when I only had two up front speakers, so I set it myself to be "Stereo". I know I don't want "Multi Ch Stereo" as that just pumps the same sound out of every speaker.
Thanks!
Thanks!
