Adjust brightness, contrast and gamma of your screen in real time. That is what the site says. Here is the site instead of a direct download link https://gamma-panel.en.uptodown.com/windows hope that helps. Well gamma-panel does nothing, I slid the slider no change. I was hoping it worked the windows calibration kind of suck. High Contrast is great, but then my games make my eyes bleed. I don't understand why dark mode doesn't do what jogh con. does minus the upping of contrast. Great dark color & it forces all app to go dark. I don't ee it as a hard thing to have dark mode do the same & turn all windows black.What the heck is gamma panel? Reflect has been hosted by at least two of us on the forums btw, there is no need to use any other link.
Last time I checkedWhat the heck is gamma panel? Reflect has been hosted by at least two of us on the forums btw, there is no need to use any other link.
just what I was looking for to test out some USBs from amazon, just to be on the safe side.Going to throw ValiDrive into the mix, which comes from the same author as SpinRite.
https://i.~ibb.co~/tKs7jBk/Main-Dialog.png
How useful have you really found it, I've seen a few similar software's. I've been using WingetUI to fetch programs.Been playing around with this free utility
Various uses
Tweaks,disable Microsoft telemetry etc
Uses winget and chocolatey to fetch programs for you bit like ninite
But lot more softwares
Has a make your own slimmed down windows section
Though found that a bit buggy
Got right to the end and it didn't produce the iso
Though grabbing the files from the scratch folder before it
Deleted them
Then making my own iso worked
The Ultimate Windows Utility
Refined over years, this utility goes beyond debloating Windows: Install and update hundreds of apps via WinGet with a single click Apply safe, practical tweaks for performance and privacy Use proven Windows Update prese...christitus.com
Gonna give this a try.. ThanksGoing to throw ValiDrive into the mix, which comes from the same author as SpinRite.
Reminded me reinstall it as I'd forgot about it.I like flux think of it as a quick night light mode which you can switch on and off easily or switch, but its much more able to custom set brightness, contrast and colour settings.
Also great for reducing eye strain, headaches and keeping your eyes more healthy.
Also tried this and worked a treat for meGonna give this a try.. Thanks![]()
Good find, agree, some interesting stuff there.some very useful little tools here
Software for professionals and beginners
Includes freeware, desktop utilities, system utilities, tips and how-to faq, guides and free Software for Windows-10, Windows-8.1, Windows-7softwareok.com
Wow that is an impressive set of tools. Thanks for thatSysInternalsSuite
No worries. It's saved me many a time. Can't claim to know what each program does thoughWow that is an impressive set of tools. Thanks for that![]()
