Bold of the forum to assume well live long enough to be killed by plastic in our water.
Plastic doesn't "leak" lad. You are confusing:The plastic leaking into water is the same. Do you suggest that plastic leaking into foods is not the same as micro plastic?
BPA free is the "green washing" equivalent to make people think plastics are safe. They have just replaced the BPA chemical with some other chemical tho.Isn't the whole plastic thing based on the type of plastic construct that's used in the container/bottle rather than a catch-all "plastic=bad" thing? That's why bottles made now have to adhere to not using certain ingredients to avoid microplastic issues.
Micro-plastics:
(beads, glitter, degradation of larger plastics)Microplastics - Wikipedia
en.wikipedia.org
Plastic leaching:
What Is Plastic Leaching And Why Is It Bad?
Plastics leach chemicals that are used during the plastic manufacturing process. These chemicals are toxic to humans as they disrupt their cell signalling processes and gene expression.www.scienceabc.com
Letting industry use pretty much whatever they want has been a major problem.I'm sure microplastics will be linked to rise in cancer at some point. It's probably more damaging long term than climate change.
Even if we stopped making all plastic tomorrow the amount in our oceans etc will be degrading for 1000s of years adding to microplastic content.
The build up in higher food chain marine animals is quite disturbing.
The words are related.
Yes they are 2 different things.The plastic leaking into water is the same. Do you suggest that plastic leaking into foods is not the same as micro plastic?
Lol dudeSemantic related words.if you really want to go deep into linguistics.
Lol dude
Like with everything something new would develop. New does not mean safe, new means we can get away from the negatives of the current issue but it could have future issues but have had time to be researched.Isn't the whole plastic thing based on the type of plastic construct that's used in the container/bottle rather than a catch-all "plastic=bad" thing? That's why bottles made now have to adhere to not using certain ingredients to avoid microplastic issues.
Seems no plastic is safe.
You would need a filtration system that is not made from plastic. Then again would the new material cause the same problems.It really is different...
Microplastics are a physical, albeit can be tiny pieces of plastic
Plastic leaching - the chemicals within the plastic are leached into the medium they come into contact with e.g. water, apple juice etc.
You could technically have water with zero microplastics via extensive filtration but it could have lots of leached chemicals
Due to the way they make and fill plastic bottles, they all contain microplastics as well as leaching chemicals from some types of plastic.Micro plastics is not the same as plastic leaching chemicals.
My initial point was you can buy glass containers and it'll still contain microplastics.Due to the way they make and fill plastic bottles, they all contain microplastics as well as leaching chemicals from some types of plastic.
There was a study recently where they dissected atherosclerotic tissue and found it filled with microplastics.
It is safer than having them in plastic containers.My initial point was you can buy glass containers and it'll still contain microplastics.
Deep semantic linguistics here but I didn't say it was or wasn't safer.It is safer than having them in plastic containers.
Yes but in a plastic bottle it'll be orders of magnitude higher.My initial point was you can buy glass containers and it'll still contain microplastics.
Why? Do you think the plastic bottle creates micro-plastics?Yes but in a plastic bottle it'll be orders of magnitude higher.
There was a study recently where they dissected atherosclerotic tissue and found it filled with microplastics in quite a high proportion.
