Bike fit done. He laughed at how low my saddle was.
Increased it 3cm and then said to increase it myself by up to another 0.5-1cm once I’d adjusted to this.
Luckily stem is fine but as the seatpost is offset. Raising the saddle pushes the it further back. He said that ideally I’d be further forward so a new seatpost without the offset would be more important than new handlebars.
Luckily I’d done some research and specced the correct width bar when buying.
Probably not ideal after yesterdays ride as I was pretty stiff/sore.
Or maybe Granada.
