- 21 Nov 2004
All sorted. The USB connector that was causing the original issue is no longer causing an issue. The new fans are now installed in the correct orientation and are also now detectable in Fan Control unlike the last lot. They also look even better, I'm almost tempted to add a set on the bottom.
I think you are right, it wasn't that obvious on the connector, but turning it around seems to have worked.
See above. No, don't think I got a sticker.
Now for some gaming!
that particular connector is keyed one way, if you install it wrong you can damage the small plastic tab inside on the motherboard side and create a ground short which will stop any pc from powering on. Did you plug it back in and flip it the other way or leave it unplugged?
I see you've fixed it, what was the actual problem then? (Cba to read the whole thread)
*Did you get a Corsair case sticker with yours? I never got one. Spending £100 on a PSU they could at least have put a bloody sticker in there lol.
