- 29 Jul 2013
That is very annoying given it’s a software featureK750 is what I had then!
Sony Ericsson K750 - Wikipedia
en.wikipedia.org
Good times.
Whoops missed this as forum never notified of a quote!
You will be pleased to learn that no, they fixed a few quirks of the MX Keys in the Keys S version.
1: You can now tweak the backlighting:
2: When you turn off and on the keyboard, or switch between paired devices, it remembers the previous brightness value. I like to keep the brightness on level 1 for max battery life using lighting, the non-S version would reset the lighting and go back to level 2 every time
3: You can now see battery % in the Options+ app for any Bolt connected devices![]()
