Hey, I've been looking at the Bilt Hamber products and I'd like to try their Touch-Less snow foam as it says it has corrosion inhibitors. Which sounds like a nice thing to have! But the whole process of finding out how much to use seems complicated and I just wondered would I do any damage if I just mixed in like an inch of product into my snow foam bottle. Does it have to be so precise? Or is there anyone who uses it can give a general rule of thumb i.e. 200ml in a 1l bottle.
I’ve used it with 3 different pressure washers, a Kränzle K7, Kränzle K10 and Kränzle D10, all with MJJC Foam Cannon Pro v2 and while I personally don’t see the issue with timing emptying a full foam cannon into a bucket and measuring the volume so it’s absolutely correct for your equipment, if you have the orifice wide open on the Venturi it’s basically 60/40 water and Touch Less in the foam cannon. You use a lot of it if you mix the PIR correctly. Our cars are not pampered at all. We use Touch Less, then wash with Auto Wash and Last Touch goes on a 1 sachet for 1 container in the Foam Cannon. And they get that weekly. And yes, I know it says not more than once per month but I’ve not seen any ‘rivulets’ on the glass which apparently is what the issue is. I also don’t spray it on the windscreen.
I think I'll go ahead and give it a try once my Avalanche Snow Foam is finished.
