Caterham Time…!
27 Jul 2007
Looks lovely, congrats!
I have a garage but there’s no way I could use it for a car since it’s full of bikes etc. What’s so bad about keeping one of these outside under a car cover?
Don
24 Feb 2004
Unless you're particularly hardcore, you won't be using it during late autumn, winter and early spring. That could mean up to 6 months sat under a car cover not being used, which generally comes with a whole bunch of issues related to damage from damp / condensation and degradation to the rubbery bits (thats before you even consider bodywork damage from being sat under a car covering through winter storms etc too)
27 Jul 2007
Ah okay, thanks. Sounds like it's a case of "man up" and use it, or not have one if you can't keep it inside.
A friend and I rented a 310S SV at Donnington in 2018 and I've never been able to shake the desire to have one since.
  • Like
Reactions: mjt
Don
24 Feb 2004
It's not a case of it being too cold (although it is, especially as many cars don't have a heater) but too dangerous too when the roads are so slippy, particularly in autumn when the roads are wet and covered in leaves. Sideways on every roundabout even at normal speeds loses its appeal very quickly. You could probably mitigate that by having a separate set of winter wheels, but then you've got to store them too.
27 Jul 2007
It’s easier to store a set of wheels than a car though :)
A friend of a friend recently bought a stunning red and yellow 420S SV which isn’t helping my yearning!
  • Like
Reactions: mjt
OP
27 Nov 2002
Don’t forget they’re not really mass produced every day cars with decades of advancement in rustproofing etc, designed for driving through the winter weather day in, day out.
It’s a mild steel tubular frame (powdercoated, yes, but it can and will chip) which is going to be particularly susceptible to the winter salt on the roads. I don’t plan on driving mine through the winter!
27 Jul 2007
Seems like a shame not to use it for half the year :/ Can they not be weather sealed?
mjt
mjt
31 Aug 2007
I used mine all year around. Wore a proper hat, scarf and gloves and it was fine. Didn't take it out if there was salt on the roads, but a bit of frost was fine. Mine was only a 1.6 with 135bhp, so it wouldn't really slide around unprovoked.
Wouldn't want to mess around in a 620 in those conditions, but the lesser models are fine!
OP
27 Nov 2002
They can - in that you could liberally coat the chassis tubes in waxoyl (or similar)… but you’ve still got the various grit traps where the aluminium skin is folded and riveted, around the chassis. Any salt getting in there is only going to accelerate the bi-metallic corrosion.
You can use them all year round, but I’d wager even a 3 or 4 year old car used year round is going to be in a worse state than a 20 year old car that’s garaged and only used in the dry.
21 May 2004
South Staffs
That looks amazing.
I always look at these and think "I really need to own a Seven at some point"...then remember how little I used my Elise and realise it'll probably just end up as as garage ornament :D
27 Jul 2007
Thanks for the info. So much to think about. These cars are so appealing because of the excitement they offer, whilst not crippling you with harsh depreciation.
I guess the sensible thing is to get something like an Elise S3, but I can’t imagine it gives you even half of the fizz.
23 Mar 2011
How's the caterham going? Starting to think about this as an option for myself. Similar budget to the OP for something like this. Not really sure which is the go to model to aim for
29 Sep 2009
Nice one OP. Would love one of these or an early Atom for track days. But don't have the space in a garage to store it.
