- 15 Mar 2007
Does a BIOS upgrade offer a performance enhancement or just to fix issues ?
Generally a BIOS update doesn't offer more performance, except for e.g. with AM5, AMD unlocked higher memory speeds. But, for AM4, you might well notice a performance improvement between the stock BIOS and the latest BIOS, as AMD made many improvements over that period.Makes sense that it is to fix an issue and that performance increases are rare, My X570 is on its original BIOS and it works fine.
You should update that because one of the Agesa updates included in the bios release gave AM4 a significant performance increase. Personally I always keep my motherboard bios up to date.Makes sense that it is to fix an issue and that performance increases are rare, My X570 is on its original BIOS and it works fine.
