I'm confused. Is it a Henry, or a Hoover?
Technically its a NuMatic vacuum cleaner
Or white pipeAlso, built this beast of a technical to get the nuts down. Each rod was taking ~5mins to wind the nut, add a plate, wind the nut, tighten. A heat gun on some FloPlast was the starting point and then I thought I'd give up as I couldn't figure out how to hold it central. Then realised.........WHITE PIPE RETURNS
Edit: there is nothing FloPlast can't solve tbh
this post is full of winAlso, built this beast of a technical to get the nuts down. Each rod was taking ~5mins to wind the nut, add a plate, wind the nut, tighten. A heat gun on some FloPlast was the starting point and then I thought I'd give up as I couldn't figure out how to hold it central. Then realised.........WHITE PIPE RETURNS
Or white pipe
Not to get you guys to full climax too soon, but I didn't even tell you that the rattan patio furniture was the jig. The bars overhang by 200mm which is exactly where the nut needed to live.this post is full of win![]()
I knew it - You are now getting like us old blokes -Is this your first Heath Robinson bodge up - Nice one you are a quick learner.Also, built this beast of a technical to get the nuts down. Each rod was taking ~5mins to wind the nut, add a plate, wind the nut, tighten. A heat gun on some FloPlast was the starting point and then I thought I'd give up as I couldn't figure out how to hold it central. Then realised.........WHITE PIPE RETURNS
Lovely floor, LVT ?
Na I'm no harm. It's @Janesy B whose disruptive. Once again he's posted a start and end in a single post - and it looks like the job is finished. I don't think I've finished a
That makes me feel slightly betterNot quite! I had been posting the odd update from the start in here. https://forums.overclockers.co.uk/t...ou-done-today.18433753/page-140#post-37006769
Can you stop putting most of us to shame please. If my wife sees this I will have her nagging me constantly rather than occasionally.That makes me feel slightly better![]()
Slow day today. I barely slept - my carpal tunnel is kicking my ass. I need the operation on both hands but just don't fancy it enough
Lost a chunk of the day "hiding" some of my rubble before covering it with the weed membrane. Then lost an equal part of the day levelling off the nut/rod system. It is very satisfying to be fair.
Also had to put a billion twist nails in the splice plates to make some 6m lengths...
(I don't think you need all nails but I was waiting for help to arrive as it isn't a one man lift)
Got 3 in as the fourth requires the offcut of the 3.5m splicing into the 4.8m and I ran out of brain cells so called it at this point...
Myperfect engineeringluck saw the rod system fall perfectly though. I don't even need to cut this, as it leaves just enough for a nut.
Tomorrow is going to be tough as my wife is at work and despite her being super pregnant she was critical to the lifting of the 6m+ lengths. I am hoping I can YOLO the last one and the sides are easy (3.5m each).
I can then chill out and spend the day doing joist hangers...
Hes building a summer house/office i believeWe had a deck once, I'd not bother again for all the same reasons everyone else says not to bother.
Not to take anything away from @dlockerers, that is a good effort.
Did you buy one of oakwoods build packs or are you flying blind?That makes me feel slightly better![]()
