They are galv and fully covered on all sides.
I wish![]()
Yeah I had another night of just pure agony. It is such a bizarre pain. Horrid.
Yeah and the videos somewhat contradict it to.
The buildpacks are quite good; I think the material list is the best bit. It just means you can do your big orders, get your materials in, then focus on each day. I could easily plan one out now but without seeing the answer first it'd be tough to get it right and not massively over/under order.
The diagrams are OK but a scan through the videos each evening prior to the next days work has been most helpful tbh.
Totally deceiving from the photo and looked like semi bright.
I guess it might be different for everyone, but mine was a cramping of the hand at the beginning with a lot of pain and towards the end, a constant vibration that I could liken to tuning forks.
Worth getting them checked out, private if you can.
With me they found out after 3 visits that it was carpal right hand and nerve damage left elbow. Forth visit, it was done and although a little pain remained for around 2 months, it is now really good to have both hands working as they should.
