Microsoft Mail ("New Outlook") - loads at start up - how to stop?
27 Feb 2004
Kent
Since Microsoft updated it'd web based email (now called "New" Outlook but not the proper Outlook that came with Word, Excel etc) this seems to open when I open windows (i.e. switch the PC on).
I want it to be "OFF" until I load it (as it used to be) but I can seem to find anywhere in settings to stop this. I can't find it in the "start up" folder?
Any ideas please?
Thanks, Me;
Run regedit.exe
Search under HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run to see if there is a key in the right panel loading oll.exe - if so delete the key.
Search under HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run to see if there is a key in the right panel loading olk.exe - if so delete the key.
That should fix it.
Run regedit.exe
That should fix it.
Neither key present. :(
