Photo and video editing desktop
6 Mar 2008
Stoke area
Hi all, looking at getting the other half a new system for editing photos and eventually videos. Current setup is old and had no issue with old D700 photos and not really any trouble with the D810, however the new Z8 and A.I. functions are killing it.
It'll run Windows + lightroom + Photoshop
I'm thinking ssd with win10/11
2 x 6tb drives for storage and backups
Motherboard and CPU
PSU
Cheap case
32gb ram
Cheap gfx card as my understanding is it's all mostly CPU intensive, but it would nice to be able to upgrade to top graphics card if the software starts using it.
Doesn't have to look pretty. I've monitors, keyboards and mice.
Budget from £1k but could go up to £2k at a push.
Any suggestions or feedback on what to look at?
What is the current PC, just to make sure this is a decent upgrade?
Afaik, the newer features that she is struggling with can be demanding on the GPU too.
AMD/DDR5
There are deals available where you can get a 7700 for around £200, so I'd see if you can find one. I think these discounts will be more widely available in the UK very soon.
My basket at OcUK:
Total: £1,567.85 (includes delivery: £11.98)​
Use stock cooler in the CPU box or get a peerless assassin/phantom spirit (for ~£35).
Intel/DDR4
Swap the 12400 for a 12600KF.
My basket at OcUK:
Total: £1,356.86 (includes delivery: £11.98)​
Cooler: as above.
Intel/DDR5, blow the budget build:
My basket at OcUK:
Total: £1,971.84 (includes delivery: £11.98)​
Cooler: as above.
£400 (incl. VAT)
£300 (incl. VAT)
£153 (incl. VAT)
£150 (incl. VAT)
£215 (incl. VAT)
£200 (incl. VAT)
£420 (incl. VAT)
£300 (incl. VAT)
£225 (incl. VAT)
£200 (incl. VAT)
£360 (incl. VAT)
£300 (incl. VAT)
Does she do it professionally, ie. she needs solid backup? If so, consider setting RAID so if one HDD is done 2nd one still has the precious data.
Separately, have another backup drive stored elsewhere.
I know it might sound daft as it's only under fairly light load but I would recommend getting a GPU with a high quality cooler. The reason being it can be very noticeable when the fan is ramping up and down when doing editing tasks. Much more so then when gaming and having a constant (louder) noise from a budget style GPU cooler.
Puget Systems have roundups for content creation https://www.pugetsystems.com/article-tag/premiere-pro/
If the version of photoshop and premier uses GPU acceleration, you can’t offload the intense rendering onto the GPU and use a midrange CPU.
I know that CPU rendering can be more accurate than GPU but I’m sure sure if that’s an issue with Photoshop or Premier (or if it’s an issue at all any more).
Any 8+ core CPU (13700 or 7800 or better) with 64gigs of RAM and a GPU with good amounts of VMAM ( more than 8gigs) would be fast.
Main thing is don't skimp on the GPU.
Lightroom and Photoshop both use GPU acceleration if you're on a recent version. If she's looking at adding DXO to her workflow (which I thoroughly recommend), it makes a night and day difference there.
GPU also has an impact on colour support - she'll really want to be able to use 30-bit colour rather 24-bit. Nvidia supports it on newer consumer GPUs (I think as far back as 20 series?), but I'm not sure about AMD.
A used 3080ti or 3080 would be quite future-proof.
8 cores is plenty for the CPU. If you go down the Intel route, 8 P cores.
Storage, get plenty. An hdd is fine for longterm storage of edited images, but it'll bottleneck an editing workflow. I'd go for a 2tb m.2 and a larger hdd.
Also make sure you have a backup option. RAID 1 is fine for hardware failure, but I'd say it's lower priority than an offline backup (RAID 1 will keep you going if a drive dies, but won't help if you accidentally delete a file). Depends how much money you want to throw at it. I use a combination of Backblaze and removable drives.
Thanks for all the comments, I've been away with zero phone signal, but seems I've a lot to go through
We do professional photography and video is more just playing around at the moment. Active adobe subscription so it's always the latest version.
I do my backups manually over a few file servers + offsite so not too worried about that element.
if you're not going to upgrade the core (cpu/mobo/ram) for the next few years then the intel 14700(k) build is the correct build for professional photography editing
