- 4 Aug 2007
- Wilds of suffolk
His numbers don't make sense to me, I think he's wrong, as does someone else in the text.
Firstly I think hes a row out on his spreadsheet for the deferred one.*
The standard one hes correct. take 5 years hes got £10660, its 9471 with 3% applied annually.
Deferred however hes wrong, its 9755 (year 2 pension with 3% added), gives 10,320, apply 3% annually for 3 more years = £11,278 hes showing 10949, which is deferred pension with 2 years 3% added.
Payback = 17 odd years. (100/5.8% = 17.24
With the 20% and the correct aging. The amount lost is only 9471 X 80% (£7577), so the payback is faster, around year 12.
With 40%, its year 10ish, because you only lost £5,682.
All above assuming as he says tax neutral. Gets rather complicated if you start adding in more criteria
* How the table should look
It used to be more lucrative so the benefit was nerfed. It used to be 1% per 5 weeks (just over 10% per year), but it was hacked back to 1% per 9 weeks. People living longer.
Year 1 | 9471 | |
Year 2 | 9755 | 10321 |
Year 3 | 10048 | 10631 |
Year 4 | 10349 | 10949 |
Year 5 | 10660 | 11278 |
Don't forget if you have enough income / savings elsewhere to consider deferring state pension, your likely to pay tax on the state pension on the way out, and then get it back if you recycle into personal pension so effectively it's tax neutral.
The reality says 98% of people at state pension age, want to take state pension and enjoy it/need to take it/have health issues and should take it etc.
I've only had 2 people I've known over 20+ years in financial servces be in a position to defer state pension/wish to defer state pension.
Take it and enjoy it. Don't put it off "to save a few quid".....
