Reinstalling NS after format
28 Jan 2011
hey guys,
got my laptop today and just spent forever sorting things out..i have a 1tb ssd and 32gb RAM on its way today..
what i was thinking was to get a super fast 512gb BOOT drive with a fresh windows install and use the 1tb NVME that is currently running windows as my data drive and send the 1tb drive that is coming today? Would it make a significant difference?
also if i done so, im guessing I would be able to reinstall the "NitroSense" software that controls a lot of stuff on this particular laptop?
Cheers guys!
SSDs are so fast these days that the difference in boot times between the different generations is a second or two, whether one is used just as a boot drive or not. In short, I wouldn't bother with a dedicated boot drive.
Once you've installed Windows, you should just be able to download and install Nitrosense
thank you.
