Hmm, not sure.
I had to make up some plugs for the outer holes that held the original plate holder. Also discovered two small holes where someone had drilled through the original plate holder and went too far in to the bumper. Plugged those too.
The main issue is the paint is much less weathered under where the holder was. I gave it a machine polish but there's no way it's going to become the exact same colour as the rest of the front without spraying.
