Yeah that's it ez fit
Now it's definitely not the first "pushfit" style fitting
For hard tube at least
@Vidar Tried some don't remember who made those
But the ability to take both hard tube and soft
Seems to be new
The ones vidar tried he had problems with
Trying to remove hard tube in situ was one I think
Will be interested to see first reviews of these
From independent builders in an actual loop
Particularly whether you can remove hard tube
Without having to cut it
In some situations yes if there's room to move one component
Might not be a problem
But if both ends are immovable wonder how easy it is
Not sure I really explained that very well
But hopefully you understand the is it difficult to remove
From a completed hard tube loop in situ
It was Barrow Wolverine fittings I tried and they where an absolute ******* nightmare! Once they gripped that was it, it was stuck and the release mechanism just didn't work right. Getting straight runs in was near impossible as they allowed no give in the tube. I had one tube snap trying to finagle it in.
