Using an old Power Supply - Corsair HX1000i PSU
28 Oct 2002
Essex
Hey all,
I've just recently upgraded my Motherboard and Processor.
AMD Ryzen 7 5800X
X570 AORUS Elite
32Gb 3200 DDR4 RAM
Aorus 1080Ti
I'm currently rocking a Seasonic S12II 620W '80 Plus Bronze' Power Supply purchased from OCUK from 2016! Someone has given them their OG Corsair HX1000i PSU in fantastic condition, Despite it's age - it's had little use. Is it worth swapping this out? Would anyone be concerned given the age of this PSU?
My current Seasonic underload gets quite loud when playing Doom Eternal.
Thoughts?
Edit - Just seen the "How long do you run a Power Supply for" thread. Quite a few people in their running old PSUs! I guess we should be good then! :D
I would take the Corsair over the Seasonic anyday. The S12II range were a outdated design when they launched let alone now. I would'nt say it's a poor quality psu but it's mediocre at best and the Corsair is leagues ahead of it in terms of quality. Exactly how old is the Corsair though?
No idea, but I'm assuming it's a year or so older than the S12!
Thanks for your replies! I'll get it swapped over.
The Corsair is much more suited to a modern system and was a premium PSU @ launch, worth more than double.
This is based on the S12II:
This I assume is your Corsair PSU:
Still got an ax860i here
Not used it for a few years other than to bleed
Air out of loops
But I would still be pretty confident
To use it given the quality of it
That's exactly it. It's just swapped it over and forgot how budget the S12 II feels when I pulled it out!
Funnily enough i was just about to swap mine into my PC. I have the exact same model. The only thing is that i only have 1 of the 12EPS 8 pin cables.. Does anyone know if the Corsair Type 4 cables are the same/compatible with the Type 3 cables/PSUs?
