- 19 Feb 2007
- Sol
Anyone here on EE's fiber ? How are the speeds and stability ?
Sound. We basically switched from BT 900mb to EE. Cheaper, no loss of service and pretty much constantly getting 750mb plus download.
I had BT 900mb full fibre for several years but recently moved to EE for much less month cost. I can’t see any difference except for the reduced monthly payment. Would recommend changing over, haven’t tried their router but any decent router will be fine.
Wow that will be some massive improvement. Good luck with that, hope you get to download so much more.Mines getting installed in just over a week, 500Mbps/100Mbps for £40 per month, Major increase in speed compared to my current 16Mbps/1Mbps.
I just tested mine and it came out as 518 down.Question for anyone who may have gotten the EE 500 fibre package, What speeds can I expect ? I know I won't get 500Mbps but what is a more realistic number ? 400 Mbps ?
Same here on Ethernet! And it’s 400-450 on WiFi for me (my iPhone)
70 upload.
It's full fibre, so unlike previous VDSL/ADSL broadband where it's limited by copper (or aluminium if you're unlucky), you're pretty much almost guaranteed the full speed. Ethernet should easily reach full speeds, WiFi may be limited depending on router placement/if your laptop/phone supports newer WiFi standards/etc.Question for anyone who may have gotten the EE 500 fibre package, What speeds can I expect ? I know I won't get 500Mbps but what is a more realistic number ? 400 Mbps ?
Oof, that sucks.Well the engineer came and he couldn't do anything as he couldn't find the ducting and chatting with a mate of mine who also works for OpenReach it turns out the block of flats I live in doesn't have the wiring set up inside so it's been a colossal waste of time and a lot of proverbial crossed wires.
Going to be stuck with 12Mbps down for the next 6 months until I move... joy.
