woooo! grats. Which one was it now? I can't keep up.Got the car!
I now, finally, have an S2000!
That gear box![]()
That gear box![]()
Congrats! What was the cost in the end?
if you're not bouncing of the limiter you're not even tryingThanks guys I'm pleased with it! Had a good time on the 3hr journey home. Tried the 6k rpm line when safe to do so and.. that's addictive!
Lovely. Looks exactly like my last one with the lip and spoiler, but with the wheels I have on my current one. Roof looks to be in very good condition.
When was the last geo?
got very dusty on the 3 hour drive home.Yea it’ll be contaminated. If you clay, you’ll need correction. So keep that in mind.Hmmm not sure I neglected to ask! I'll dig through the papers later for evidence of if and when it had last been done!
Expensive?
Gave it a quick was tonightgot very dusty on the 3 hour drive home.
I did notice the paint kind of feels a little dusty to the touch, hard to explain like rough but in the most minor sense.
Could this mean it needs a good claying/polish?
There may no signs if it’s seized in the right spot but usually geo goes after a while by default. Potholes etc knock the alignment out a bit and you may not get the best out of the car handling wise for example. In my case I also wanted a track setup so more camber etc.Ha.
Will look into it. Why does one look to get a "Geo" done in the first place? What are signs that it needs doing or isn't right so to speak?
The road to our office is shot to bits and I feel every bump.. so will look into thisThere may no signs if it’s seized in the right spot but usually geo goes after a while by default. Potholes etc knock the alignment out a bit and you may not get the best. In my care I also wanted a track setup so more camber etc.
Shall look into it!While you're underneath, remove the clutch delay valve. 10 minute job and massively improves the clutch feel.
