- 10 Sep 2006
- UK
No real point in the Ora/YU2 unless you have size restrictions. Go bigger if you have the space.
If you're looking to save space and want small speakers then I can recommend iLoud micro monitors - https://www.ikmultimedia.com/products/iloudmm/
There's enough youtube vids, reviews and comparisons online for them.
My own thoughts though - Having owned 'desktop speakers' for years, the iLouds are certainly the best by a long way. They put out similar sound as a speakers 4x their size.
Ive seen that guide years ago when buying thrm and had them on stands.Will need a sub to add bass to help out those 3" woofers. Won't need much a BK Gemini or something like that would do, if your soundcard has 5.1 analogue out then use the soundcards bass management feature, probably cross around 80hz or so.
Use this is a guide where high passing the speakers
IK Multimedia iLoud Micro Monitor Review
noaudiophile.com
