Gaming headset recommendations?
29 Aug 2010
Cornwall
So it looks like my Steelseries Arctis 1 headset is on the way out.
Any recommendations for a headset with good sized ear cups (is that the term?) and a decent microphone?
Also needs to use a 3.5mm connection (either split into headphones and microphone or includes a splitter).
I don't want to spend silly money as I only use them when gaming with friends or playing games where directional audio is important (I'm thinking under £100, but it really depends on how much over and what I get for that). That said I don't want them to be so cheap that they're no good or will fall apart in no time.
I'm also not a fan of the fake leather stuff that ends up flaking off, but it's not a deal breaker.
I quite liked the Arctis 1s. I like the floating headstrap thing but wasn't overly keen on the way the microphone retracted. They seemed comfy enough though. The model I have seems to have been replaced though and I'm not sure if the new ones are as good.
So yeah, would appreciate any suggestions.
Thanks.
I've just upgraded from a 4 year old pair of Arctis 7 wireless with Micro USB charging to a Nova 7 headset, massive difference in quality and battery life. The headset itself is lighter although the buttons take a bit of getting used to.
Arctis pro wireless!
You get two batteries with them.
Pricey mind but are good .
Just bought the Turtle Beach Altas Air and they are incredible (about £160). Open Backed though so sound may leak a bit but they sound great with games - sufficiently so for fps games that I'm ditching the Audeze Maxwell. The TBs are a real surprise to me. Removable, flip to mute mic also so can be used for music listening if needed.
this would be my choice if i was buying now, purely based on comfort.
light, low clamp force on head, nice ear cups and sound can be EQ to suit.
Something I don't see recommended often but have been the best headphones I've ever owned. The JBL Quantum 810. Work wireless with USB and wired with 3.5mm
I have to say I have been tempted by these, particularly for use with the PS5 (I've sold the Series X now). Great feedback on them.
The appear to be comfy, light, great battery life and measure very closely to the harman target. Albeit with more treble than the PC38X/Maxwell (according to Gadgetry Tech on YT). Again I've been trying to really stick to 'less is more' and the trifecta of my HD650/PC38X/H6pro setup. I don't need anymore headphones! But again tempted.
I'm also after something exactly the same as the OP asked for "Also needs to use a 3.5mm connection (either split into headphones and microphone or includes a splitter)." it seems that all the recommendations are wireless apart from the JBL's that 'RaiderX' recommended . . .
I switched from sennheiser pc350s (wore out) to pc 37x (open back) to beyer dynamic dt770 pros (changed as I needed closed back for recording/streaming)
I like the dt770s the best, I'd like a removable cable like on the pc37x's as its what broke on my pc350's but it does feel very sturdy, they are very comfortable, large soft cups, nicer/better sound and cheaper due to no gaming/headset rubbish.
They really are very good imho - always prefer open backed and so these replaced my Audeze Maxwell and Astro A50x I had. Not regretted it for a moment - especially now that eq is available in the mobile app also. Have kept the Tygr 300R and HD660S2 for wired gaming and music when needed though.
About to pick these up, had a cheeky £100 Curries vouchers. Fingers crossed they're good.
My sense is that they will be very strong for online/competitive FPS, particularly. I'm with you on open vs closed-back - albeit it's nice to have a closed-back on hand for some scenarios.
I have bought a Soundblaster X1 again which I currently use on PS5 with any of my wired headsets and it works well. Particularly in my small office. So again I don't need new headphones and need to keep telling myself that! I did think for a long-time the new Pulse Elites were going to be a purchase but the huge noise online around disconnects, crinkly drivers and comfort have put me right off. Shame because it's only the Sony PS accessories that integrate nicely with the PS5 OS.
Are there issues with volume on the latest firmware just seeing a lot of users reporting issues. I'm tempted to get one though.
I haven't updated mine in a few weeks so will check for an update later.
On PS5 they aren't the loudest I've owned but there is still enough headroom for me so I never need to use them near max volume. I'll check how they are with PC later and report back once I've checked for an update :)
I would get a separate amp and headset instead if possible you will get superior sound stage, imaging and bass response. Something like beyerndynamics DT990, DT880 or Audio Tehcnica AD900X. little more than what you want to pay but much better sound quality. You can get a separate microphone if you need on.
