Best thermal paste
He asked for the best performance so it's liquid metal. But agreed it's downsides are just too much outside of benchmarking and going for records
You don't use LM for records, as it is useless below sub-zero. You should always use a good paste (KPX etc..) for DICE / LN2, but that isn't the average user here.
:p
Lets see then :cry:
Right to follow up on this then:
24c Starting Water Temp
24c Room Temp
CPU: 14900KS - Locked at P:57 / E: 45 / C:45
WB: Aqua Computer Cuplex Kryos NEXT PVD / Nickel - WB
MB: Asus Z790 Apex Encore
RAM: G.Skill 8400 C40
Test: R23 - 10 Minute (Test Throttling)
14900KS - Core Max Temp (After 10 mins)
Artic MX-6 / 82c
Noctua NT-H2 / 80c
Kryonaut / 80c
Kryonaut Extreme / 79c
Kingpin KPX / 79c
Conductonaut Extreme (LM) / 74c
KPX is my favorite currently, there was a 5 degree drop in all core load temps over the previously used Thermal Grizzly on my 13700k using my Corsair AIO
Does anyone in the UK even stock it, remember looking a while ago and not finding anyone?
24c Room Temp
Artic MX-6 / 82c
Noctua NT-H2 / 80c
Kryonaut / 80c
Kingpin KPX / 79c
Pretty hot. What’s the rest of the loop?
No unfortunately. I got mine direct from the source cost approx £60 (including shipping) for 30g which is cheaper or about the same price as 30g of Thermal Grizzly from the UK. Ordered on a Friday arrived the following Wednesday no import fees.
Shame it can’t be bought in the UK at a lower price, because it might give AS5 a run for its money now prices are rising. What is KPX like to apply?
I’d be tempted to lap the chip and block. I’ve seen 10-15c drops just from that.
Normally I have a TG direct die block for the CPU but for these tests, I used a stock IHS so I can test each of the different pastes.
I've never seen a 10/15c drop from a lapped IHS which I have tried on a lapped EK WB and saw a few C's at most. Direct Die normally has the biggest gains around 10-20c in some cases as I have seen huge drops on AM5 / LGA1700 when I have tested both using Thermal Grizzly DD blocks
I've never seen a 10/15c drop from a lapped IHS which I have tried on a lapped EK WB and saw a few C's at most. Direct Die normally has the biggest gains around 10-20c in some cases as I have seen huge drops on AM5 / LGA1700 when I have tested both using Thermal Grizzle DD blocks
I’d have expected better considering the amount of money you must have spent on cooling kit.
Not sure what you are expecting
The same CPU with a direct die will run P:60 / E: 48 / C:50 around the 70's for the same test.
Piece of cake, line down the middle of the CPU and then spread evenly with the supplied spatula. £'s to Grams i think its cheaper then AS5
AS5 is getting more expensive. The trick is buying the 12g tubes on offer. The larger tubes do come up from time to time. I might give this go some time.
I am rocking the Thermal Grizzly Kyrosheet on my 7600, I don't do any CPU intensive tasks any way.
CPU temps are fine during gaming.
