I've now had an estimate through from Easy PV (note this is an estimate at this stage).that quote is ridiculous you can get that for around 8-8.5k fully installed and comissioned, mcs dno heis'd up (i'd estimate with additional panels you want) from he suppliers who installed mine -
Solar panels and battery - any real world recommendations?
You'll pay 20% VAT on battery without solar panels installed with it. You'll still need an inverter. Someone will have to install it. May need DNO application if it can export. Reliant on a cheap off-peak tariff always existing that you can get onto. To some degree here you may as well just...forums.overclockers.co.uk
i have 12panels, 13.5giv battery 5kw inverter and 6 tigos, all wiring and the parts, cabling and the unit that goes at the meter
they said any addional panels fully installed will be £130 a pop, tigo were £40 a pop, i have a chimney so we agreed 6 to be on the safe side
For a similar 6kWh system and GivEnergy All in One system, it's £12,500. Only £700 cheaper than what you believe is a ridiculous quote.
The materials alone come to £10,500.
An additional battery would work out at an extra £5,600.
Somebody mentioned/suggested E.on. Their estimate for a 16 panel PV only system is £8,064. £1,620 more than the quote I shared in my post. Except that doesn't include panel optimisation, that's another £1,738.
E.on is, as I suspected, a lot more expensive.
