- 25 Mar 2004
- Fareham
You'll pay 20% VAT on battery without solar panels installed with it.
You'll still need an inverter.
Someone will have to install it. May need DNO application if it can export.
Reliant on a cheap off-peak tariff always existing that you can get onto.
To some degree here you may as well just get panels with it, you're more likely to find a company that is willing to install both in an official capacity. Most installers probably won't entertain just coming along to install a battery only, especially if you buy it and not them.
Does up the cost but then you wind up with best of both worlds, and you can fill your own battery a lot of the time.
